Old 07-26-2016, 01:12 PM   #1
Entry door stuck shut on Forester
I have a 2014 Forester and last night we shut the coach entry door and now cannot open it. We can enter via the cab door but the coach door is stuck shut. I was going to try and unscrew the door handle but the screen door blocks one of the screws. Any suggestions?
mrmilo is offline   Reply With Quote
Old 07-26-2016, 01:16 PM   #2
AquaMan's Avatar
Is it unlocked? Pull the door towards you, pull the handle and push from the inside. A slight shoulder nudge may help also. I had a door get stuck during a cold spell, where the door shrunk at a different rate the the coach. I've since adjusted the latch and it doesn't happen anymore.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-26-2016, 01:37 PM   #3
Door is unlocked and I've tried pushing and pulling from the inside and outside while pulling the handle. But it just won't open the latch.
ID:	115372   Click image for larger version
Old 07-26-2016, 03:58 PM   #4
We had this happen one time in our Wildwood TT when one of the screws on the door catch backed out. The door would not open no matter how hard we pulled.
Our only solution at the time was to literally drill out the hinges of the door. They aren't like regular house doors where you can just pop a pin out. Eventually got the door off then IIRC, we just cut up a metal coat hanger to slide back into the hinges.
Also put some lock-tight on the screws so they wouldn't back out again.
Don't know if this is the problem you're having or not but it's a possibility.
Iwritecode is online now   Reply With Quote
Old 07-27-2016, 12:25 PM   #5
widogmom's Avatar
We have this same lock on our Sunseeker, and it comes out of adjustment & jams all the time...very frustrating! Try lifting slightly before you pull (or push, from the inside) and see if that works. We're going to replace ours (round tuit schedule). Good luck!
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
widogmom is offline   Reply With Quote
Old 07-27-2016, 12:34 PM   #6
padcarroll
I have the same one on my 14 Legacy. I recently had the same issue. An internal part broke that pulls the latch back. If the handle pulls freely with no resistance than you probably have the same problem. I picked up a updated version of the same lock at CW.
Dave and Pam Carroll
Callie - 9 yo chihuahua/yorky mix
2014 Legacy SR300 340BH
2013 Chevy Sonic Toad
Full-timing since January 2016
padcarroll is offline   Reply With Quote
Old 07-27-2016, 01:15 PM   #7
Bingo. The latch bolt itself was broken inside so the door handle could not retract the latch. It will need to be replaced but I can still lock the door with the deadbolt. Thanks all for the replies.
Old 07-27-2016, 01:54 PM   #8
padcarroll
That is exactly what happened to mine except it broke right where the rails met the back piece. Here is the replacement part number from CW.
Item No. Description Price Ea.
70814 Entrance Door Lock With Deadbolt $93.94
Old 07-27-2016, 02:40 PM   #9
My Solera has the same lock and jams occasionally. I tightened the screws and that helped a little. It has jammed up on me on a couple of hot days this summer, only to open in the evening after it has cooled back down.
mtnlvr is offline   Reply With Quote
Old 07-27-2016, 04:43 PM   #10
ov845's Avatar
Upgrade to a keyless entry for a few bucks more.
https://www.rvlock.com/collections/r...eyless-systems
Good strong locks. We have 2 doors and replaced both. The kit was easy to install.
Happy Camping!
2012 Ram 1500 Crew Cab
Engine 5.7L Gear 3.92
Airlift 1000
2015 2809W WindJammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
door, forester
