Old 10-31-2016, 09:48 PM   #1
Frame less window opening on its own.
Have one window that likes to unscrew a little while on the road. Then it will flap back and forth causing the arms to come out of the track on bottom of the window glass. Even had to replace the pot metal crank that I broke thinking It wasn't getting tight enough. Anybody else having this problem? Trailer is a Flagstaff 27 RLWS
bohnker is offline   Reply With Quote
Old 11-01-2016, 09:53 AM   #2
raspivey's Avatar
I've got the Rockwood version...haven't had that issue. In fact, mine don't want to open sometimes due to being extremely tight. I'll go take a look at mine sometime today. There may be a way to just wrap the threads with teflon tape to give it more resistance.
Old 11-01-2016, 10:15 AM   #3
Better yet, a dab of blue threadlocker.
SidecarFlip is offline   Reply With Quote
Old 11-01-2016, 08:22 PM   #4
raspivey's Avatar
If you did that, you'd have to reapply it every time you wanted to open the window though.
Old 11-02-2016, 12:31 PM   #5
Worse than that
We have a similar, but worse problem.
The window started flapping open while driving and the scissor-type attachment is broken. Perhaps we just lost the screw. not sure. Hard to see.
Had to use a bunjie cord to keep it closed -- and I had to great creative to accomplish that. Then that only worked for awhile.
Can't figure out how to get a replacement.
Linda
Solera 24R
Washington
PNWTraveler is offline   Reply With Quote
Old 11-02-2016, 12:41 PM   #6
mule's Avatar
We had the same problem (x2) on our 2015 27RLWS bedroom window. Finally took the second twist crank from the dealer and fixed it myself with machine screws and lock nuts, NOT RIVETS. And as a few others have said, try not to over tighten. It would nice if the windows had propout levers like the egress windows, but have 3-5 stop positions so a person could have multiple points on how wide a window could stay open, just a thought!
mule is offline   Reply With Quote
Old 11-02-2016, 04:06 PM   #7
Frameless window opening on own
This appears to be a common problem. There is another thread regarding it. Mine came open at 65 mph on I80. The ends of the crank piece were lost. Had to replace the crank arms. Dealer got me the part for $20 less than FR quoted me (the crank we have a 9.5Ē part number 10-19668A /60.40
The knob is 10-19627A /2.00}. Drilled the rivets out and used stainless steel bolts and lock nuts per the advice of another poster. He pointed out that he used a set of vice grips on the knob to keep the window closed, since replacing the part wasn't enough. I have attached a picture of my solution. Hoping it works. I won't know until back on the road in the spring. Two .97 clamps from WalMart. I have also attached pictures of the crank arms without the window ends, and my temporary solution. Duct tape on the outside didn't work for crap.
ID:	124537   Click image for larger version
ID:	124539   Click image for larger version
RStormC is offline   Reply With Quote
Old 11-02-2016, 04:44 PM   #8
mule's Avatar
Have you tried contacting Lippert Components (LCI) directly and explain to them what you need? I wouldn't be surprised if they sent you a new assembly via UPS "no charge"!
It's worth a try!!!
Old 11-02-2016, 04:52 PM   #9
frameless window opening
This has apparently become a common problem on Forest River products. Especially at the front end of the trailer, and where there is nothing to break up the air flow to the window along the side. FR must be well aware of this by now and should be looking at a recall. But that is highly unlikely.
Old 11-02-2016, 05:11 PM   #10
Ran into this same issue but mine had a mechanism that flopped around and appeared to be broken compared to other windows in camper. See this previous post:
Frameless Window fixed- Rockwood Mini-Lite 1809S
Since we had it repaired, the window has not reopened again but we also stopped traveling with the roof vent open as well. Some posters think this may be related in some manner. I will be towing with vent open next season just to see if it happens again.
I will try the Walmart clamps suggested above as a backup repair if it opens up again some day.
J and S
2016 Rockwood MiniLite 1809S Sapphire Edition
2013 Ford F-150 SuperCab XLT 4WD 5.0L 3.55 rear Factory anti-sway and brake controller
Equalizer E4 - 600 TW, 6000 GTW
Indi the Camping Havanese
JandS is offline   Reply With Quote
frame, window
