Old 01-14-2013, 11:01 AM   #1
Front door lock on 2013 VLite Flagstaf
I by mistake put the wrong key in the front door of our new camper and turned it ... Well we can't get the key out of the lock at all now . Since it was the wrong key (which looks just like the other door key) but I guess I did wrong when I tryed to turn the key which did turn but stuck in the position that it will not pull out .Any suggestion as to how to remove the stuck key without taking it in to the dealer .
Thanks Toots
toots is offline   Reply With Quote
Old 01-14-2013, 11:39 AM   #2
With the assumption you are not "locked out" you could remove the lock and find a locksmith which might be closer then a dealer. Otherwise, a set of needle nose pliers, a pick or two, lots of fussing around.
Good luck,
Mike
traveler2955 is offline   Reply With Quote
Old 01-14-2013, 07:44 PM   #3
bikendan's Avatar
any locksmith should be able to fix it. may have to buy a new latch, though.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
