Old 08-01-2018, 11:11 AM   #1
Heymirth's Avatar
Frt Door only opens 90
Hello, Our "new to us" 2015 Palomino Hybrid has a hydraulic front door, this lets the front door only open to 90 degrees. this seems like a little issue, especially with kids running in and out. I know its a great door for high windy days BUT---
What can I do to remedy this situation?
Does anyone have this type of door also?
Heymirth is offline   Reply With Quote
Old 08-01-2018, 11:18 AM   #2
PPST Wannabe
kenandterry's Avatar
I donít know what your rig looks like, but is it possible that if the door went past 90 degrees, it might strike another object.....awning support arms, or slide out, or some attachment on the side of the rig?
Have a real good look and let us know whatís in the path of the door past 90 degrees.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 08-01-2018, 11:25 AM   #3
Denver To Yuma In 90 Days
It opens like that for a reason...
Probably, like already mentioned, would be in the way of an awning arm or some other thing.
I have that too...
It is a PITA, but I've learned to just live with it.
JohnD10 is offline   Reply With Quote
Old 08-01-2018, 12:58 PM   #4
jeff64's Avatar
I used to have the gas shocks on mine. Took them both off and put the old style T latches on them. Just had to consider the placement of a 6" latch to clear a tilt out window. If you're not fighting the position of an awning arm it might be a possibility
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-03-2018, 07:45 PM   #5
dmchapman's Avatar
This is exactly what I did, too. The door tended to flap in a light breeze as built.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 08-03-2018, 10:49 PM   #6
Fulltime family RVer
Same but I used magnetic catches vs T-latches.
Old 08-03-2018, 11:45 PM   #7
bikendan's Avatar
If you posted a pic of your door, it would help with suggestions.
I agree that it's to prevent it hitting or restricting something like the awning arm.
Since you don't mention the model number nor is it in your profile, we can't look at the floorplan.
Equalizer WDH
Old 08-04-2018, 06:32 AM   #8
NH Maple Maker
russhd1997's Avatar
The gas piston on my door had been removed by the previous owner and I replaced it. It keeps the door from hitting the awning arm and it keeps the door from blowing around in the wind as well. My door is wide enough so that we don't need to have it open farther than 90* and most of the time we leave it open and use the screen door to go in and out.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 08-04-2018, 07:08 AM   #9
We had the same problem with our 2012 Flagstaff 5er and I just moved both of the gas strut anchors 2-1/2" closer to the hinge. Now the door opens to within 1" of the awning strut.
Name:	Relocated anchor on trailer.JPG
ID:	182240   Click image for larger version
Name:	Relocated strut.JPG
ID:	182241   Click image for larger version
Name:	Both anchors relocated.JPG
ID:	182242   Click image for larger version
Name:	Close up relocated anchor on trailer.JPG
ID:	182243   Click image for larger version
Name:	Door anchor relocated.JPG
Old 08-04-2018, 07:13 AM   #10
KyDan's Avatar
Depends on your rig.
My gas strut door had not obstructions so I removed the strut (mine just popped off the ball ends) and put on magnetic catches. Now it opens all the way back against the wall.
My only disappointment was the magnets were advertised to have 9 Lbs hold power.
I'd guess they're more like 2 or 3 Lbs.
Still enough unless it's really windy.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
door
