Old 03-08-2016, 07:50 PM   #1
Georgetown 350TS Main Door
I'm having an issue with the main door bracket attached to top of door. It's not keeping the door from swinging pass the length of the shock strut. Keeps pulling the bracket loose. The metal is soft and doesn't hold the bracket in place. Any suggestions on how to keep the door from swinging to far? Bracket holes are just about gone.
garytenorsinger is offline   Reply With Quote
Old 03-11-2016, 09:47 AM   #2
Some photos of the effected area would be helpful.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 05-09-2016, 02:41 AM   #3
Had the same issue. I put a "leash" on the door handle to guide the door out and to pull it shut when entering. Used 2 "woven parachute cord bracelets" linked together through the handle. The holes in door stripped? I put a appropriate length of solid copper wire in hole then reinserted the screws. Copper wire narrows the hole and is soft allowing the threads of the screws to bite into the wire. So far so good. The "leash" prevents a sprung door and it is much easier on me coming or going as an extension of my arm
360 Georgetown XL 2015
twoclaws is offline   Reply With Quote
Old 05-15-2016, 08:46 PM   #4
c5hydro's Avatar
Cool Georgetown 350ts main door bracket
Photos of a very weak bracket. Had ours over extend several times. Would be nice if Forest River would fix this.
c5hydro is offline   Reply With Quote
door, georgetown, georgetown 350ts
