Glass replacement
How to remove the lower vertical sliding window panel to replace the U shape piece of glass. This window has two horizontal sliding tabs that lock into holes in the window channel. I took off the interior trim to see if that would allow me to remove the whole window and frame but the window is still contained within a channel. I tried to remove the Philips screws that hold the top aluminum frame to the U shape frame but without removing the window, I could not get a bite on the screw heads.
