Old 11-06-2015, 12:32 PM   #1
Chuck.C's Avatar
HEHR window problems
I have HEHR single pane windows on my coach. On two of them so far the leading edge strip that has the latch toggle has come off, along with the rubber strip that apparently is intended to hold it in place. Seems to be only a pressure fit. Has anyone had this problem, and how have you addressed it? I'm hesitant to try to tap it in with a hammer, being right up against the fixed part of the window.
2013 Coachmen Mirada 35DL
Chuck, Susan, and Gracie the Registered SnackHound. RIP - Toby the Wonder Boxer
Chuck.C is offline   Reply With Quote
Old 11-06-2015, 12:45 PM   #2
Keystone's Avatar
I had that issue last year. Used a bit of silicon adhesive and it's held since.
US Army, 1979-1990 95BZ6
Keystone is offline   Reply With Quote
Old 11-06-2015, 12:56 PM   #3
Chuck.C's Avatar
Thanks. I thought of using an adhesive, but I can't get the old gasket and metal on with reasonable force. how did you get it back in place?
Old 11-14-2015, 02:59 AM   #4
I just had the same problem occur, and I am also concerned about the force needed to get it back in place. I would rather try and fix it myself, rather than take my MH to the dealer and wait weeks to get it back.
jimcarterhb1951 is offline   Reply With Quote
Old 11-14-2015, 07:38 AM   #5
Chuck, don't take a hammer to glass, never a good outcome. Try TLC in lieu of.
Old 11-14-2015, 08:26 AM   #6
KyDan's Avatar
I have not done this but I believe the black RTV (silicone) would act more
or less as a lubricant allowing you to press the rubber and metal strip back
onto the glass. I have an old rubber mallet that I'd probably use in your
case. (A relic of the old days when cars had "wheel covers" that had to
be hammered back on.)
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 01-02-2018, 09:09 AM   #7
twojump36's Avatar
I'm having the same problem... 3 windows so far... It must be a bad design. I can not get the rubber insulator back on the glass with the aluminum latch / trim.
I'm considering just re-bedding the glass to the aluminum without the rubber with clear silicon.
I can't believe this isn't a major issue on here and people haven't blown up the Forum on this issue...
2015 FR3 30 DS
1995 Wrangler
Miles 8250
Days Camped 62
twojump36 is offline   Reply With Quote
