Old 11-21-2018, 11:04 AM   #1
wmbuttion's Avatar
Hehr windows
Foam strip between glass and frame keeps popping out just in the corners. Any suggestions from this happening?Click image for larger version
ID:	191923Click image for larger version
wmbuttion is offline   Reply With Quote
Old 12-02-2018, 08:49 PM   #2
Is that the rubber gasket?
AbdRahim is offline   Reply With Quote
Old 12-03-2018, 07:54 AM   #3
wmbuttion's Avatar
Yes it is. You can push rubber gasket back in but still comes out.
Old 12-03-2018, 11:05 AM   #4
I have the problem. It happens when the slide seal rubs by the window. I spray it with silicone after I snap the gasket back into the channel. That helps it for a while.
Gotta go campin!
Old 12-03-2018, 11:14 PM   #5
Looks like the gasket may need to be replaced and installed properly.
window
