Old 09-24-2014, 09:13 PM   #1
Help!
My wife and I are new to camping. We had our first outing in our 2009 Forrest River 22bh. I just noticed today the awning support on the bottom was bent in and the aluminum had separated. There were some strong winds on our first outing but I just now noticed the damage. Any thoughts? Sorry in advance for the crummy pics. I was able to bend the bracket and metal siding out as far as possible (the pics are after I did so). Also the two mounting bolts will not tighten up. Would it be ok to get two that are slightly larger and longer? Should I put a clear silicone to cover the gap in aluminum?Click image for larger version
Name:	ImageUploadedByForest River Forums1411611164.521833.jpg
ID:	63492Click image for larger version
Name:	ImageUploadedByForest River Forums1411611189.403936.jpg
nanderson is offline   Reply With Quote
Old 09-28-2014, 10:49 AM   #2
Yes, you can put longer larger diameter lag bolts in and see if that will tighten up. I assume that the gap that requires filling is at the dent in the first picture. If so, you can use silicone to seal the area.
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 12-23-2014, 12:47 AM   #3
Just make sure its an outdoor windows sealant and not bath/kitchen one
Kuba is offline   Reply With Quote
Old 12-23-2014, 05:41 AM   #4
Herk7769's Avatar
I would by "roll" butyl caulk ( 1/2 to 1 inch wide) and remove the bracket completely; clean the old caulk off; squirt a bit of silicon cement into the holes; cover the back of the bracket with the butyl tape; using the next size up stainless steel screw; reinstall the bracket; trim around the bracket after install to remove excess tape.
This is a permanent repair.
http://www.butyltape.org/motorhome-t...nt-tacky-tape/
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
