Old 05-28-2013, 04:06 PM   #1
Help, awning now not retracting
I put my awning out today to check the alignment and now it will not retract. I checked the voltage at the connector out at the end of the roller and had plus and minus 14 volts when switch is toggled. I can hear a little ping sound when the switch is first enabled but that is all.
Any suggestions? Sure it had to happen now, 2 days before we shove off on a month long trip.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 05-28-2013, 04:18 PM   #2
I have found that there is a recall from another thread. I will work it from there. Thx...
2016 Siverback 33IK
