Old 09-16-2019, 06:02 PM   #1
Brake is on left
The Evil Twin's Avatar
Help- Awning will not fully retract.
So packing up after an extended weekend, I noticed that our awning did not seem to completely roll up tight against the rig. It stopped just shy of nesting the two arms at the top. I thought it was maybe an end switch but the fabric is taught and it looks like the roll may be a little high. It is the same on both ends. Anyone have any ideas on what may be the deal?
ID:	215156   Click image for larger version
The Evil Twin is offline   Reply With Quote
Old 09-17-2019, 08:16 PM   #2
Watching
Iíve got the same issue
Eric1960 is offline   Reply With Quote
Old 09-17-2019, 08:37 PM   #3
Mine did that but only on one end . Turned out it had somehow slipped in the track on the tube and was rolling up crooked it was a bugger to get it straight in the track but it fixed it . I put a screw in the track on both ends to keep it from happening again.
Sfgoble is offline   Reply With Quote
Old 09-17-2019, 10:08 PM   #4
Kasual Kamper
Good tip! I'll have to try that.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 09-18-2019, 06:42 AM   #5
XenoRev's Avatar
Now I'm curious, because mine is like that. I just had assumed that's the way it always is.
I need to go by an RV lot and look at new ones like mine to see.
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
Old 09-18-2019, 07:09 PM   #6
Brake is on left
Lol. I'm not special.
I assumed they were supposed to nest the upright bars evenly. The bottom of mine are nested (fixed support inside the moving arm) but the top is not. It is even on both sides, and the fabric rolls over the top of the drum as it should. It just seems to stick out a little at the top.
Old 09-21-2019, 07:42 AM   #7
Looks like you need to slide the awning toward the rear. Extend the awning, from rear, lower arm as much as possible, grab awning near roller and pull while pushing at m forward. You should be able to slide it until it’s straight and closes properly. Then put a short screw in to hold it in place. Had to do this on my 20ft awning.
lewisra is offline   Reply With Quote
Old 09-21-2019, 08:26 AM   #8
Brake is on left
Originally Posted by lewisra View Post
Looks like you need to slide the awning toward the rear. Extend the awning, from rear, lower arm as much as possible, grab awning near roller and pull while pushing at m forward. You should be able to slide it until itís straight and closes properly. Then put a short screw in to hold it in place. Had to do this on my 20ft awning.
I see what you are saying because the fabric is not evenly rolled but (I believe) it is the same on both ends. Almost like the camper side is slightly narrower than the outboard side. I will double look today.
When you say "lower arm as much as possible", do you mean with the tilt adjustment?
Old 09-21-2019, 08:36 AM   #9
Shifted fabric is the most common cause of what you describe.
Also check the distance between the rails that attach to the side of the R/V to be sure it is the same top to bottom. They could have been put on unparallel but it would have always been this way. Maybe you just noticed it?
Also make sure the adjustment knob for the angle/tilt is loose enough. I forgot to loosen one on another camper once and one side stuck up when retracted.
Days Camped: '16=46 '17=30 '18=51 '19=50
awning
