Old 03-09-2019, 08:59 PM   #1
007matman's Avatar
Help! Dometic 9100 Awning Fiberglass Camper Mounting
Hello all!
Camper: Rockwood Signature ultra-light (fiberglass walls)
I had to purchase new mounting arms for my Dometic 9100 series Awning as the old ones bent during a torrential downpour last fall.
I found a used set on eBay for half the price of new. However, it did not come with any mounting hardware. There are two bolts that secure the top. However, the bottom are mounted with pop rivets.
I am trying to is 3/16th pop rivets but they won't hold. It appears the the hole is slightly larger. However, that's the largest I can find locally.
Anyone know what type of rivets should be used to secure the awning to the side of the camper?
007matman is offline   Reply With Quote
Old 03-09-2019, 09:24 PM   #2
bubbles's Avatar
My motorhome has sandwiched aluminum sides and screws are used to hold the awning side rails in place. I believe the awning comes with Oscar rivets when ordered as a kit and they are for fiberglass installs. I think.
Old 03-09-2019, 09:27 PM   #3
bubbles's Avatar
Washers might be used under the rivet head if the hole is oversize.
Old 03-09-2019, 09:39 PM   #4
007matman's Avatar
Oscar rivets!! That's what they're called. Makes sense. A quick search on Amazon and these babies showed up.
Dometic brand even.. looks like it's the right part. Expensive little guys!!
Dometic 113008P 3/16" Diameter Oscar Rivet, (Pack of 6) https://www.amazon.com/dp/B0031NJIM4..._zJhHCb7NXHZ8N
Old 03-09-2019, 09:50 PM   #5
bubbles's Avatar
They're only expensive if your awning flies off your unit while tooling down the road.
Old 03-09-2019, 09:59 PM   #6
Originally Posted by 007matman View Post
Hello all!
These are a bit cheaperhttps://www.albanycountyfasteners.com/316-6-low-profile-flat-head-tri-bulb-rivets-with-sealing-washer-aluminum-p/2066-002.htm
MR.M is offline   Reply With Quote
Old 03-09-2019, 10:00 PM   #7
007matman's Avatar
Let's hope that doesn't happen!
Thank you!!!
Old 03-10-2019, 06:03 PM   #8
Cheaper here
Cheaper here.
Larry-NC is offline   Reply With Quote
Old 03-10-2019, 06:52 PM   #9
007matman's Avatar
Originally Posted by Larry-NC View Post
Cheaper here.
Ouch.. I shoulda been less trigger happy.. :-)
Old 03-10-2019, 07:04 PM   #10
Cheaper here.
Until you add the shipping . don't understand why these are so pricey ,
awning, camper, dometic, fiberglass, mount
