Old 07-30-2014, 11:05 AM   #1
Question Help for removal of frameless window
Has anyone removed the tilt out frameless window? I was hoping that this would come out easily. Would like to add a removable cat patio/cage once the window is off. Of course, prior to traveling I would need to reinstall the window.
I can see how the window crank mechanism works at the bottom and how to remove this but I can't determine any hinge mechanism at the top.
Last resort would be to use one of the two double hung windows for the cat patio--but they are on each side of the sofa/dining slide. I can see a future crunch if located in that position. Forget one time, (bound to) and within the first 6 inches the cage would be squeezed against the outside wall.
Will try to attach two pics for my window.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
frame
