Old 05-30-2016, 06:33 AM   #31
Wolverine 1945's Avatar
Originally Posted by MCTroy View Post
I agree! ,I can't tighten ours enough to dip one end for shade. It stays 10 -15 minute then POP up it comes.. I know there are pole kits available to hold the awnings down but DH said no to that idea. He wants to tie one end down. Anyone had any success doing that? What could we break.if we put a rope on one end and staked it down.?
We have always tied ours down,,, but both ends,,, not just one end !!!
You can tie one end down lower than the other if needed !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-30-2016, 11:17 AM   #32
I have the first year Dometic made an electric awning. It was not adjustable! I contacted Dometic and they sent a new arm for the rear arm. I had to have a dealer install Only way they would send the new arm. It was a mistake on their part and the corrected the problem. This was only on the first year they made the electric awning 07/08.
Yours looks adjustable. Loosen the black locking knob and the two pieces should slide together, Just like the mechanical awnings do. That knob is a lock knob. Once loosened the "silver beam should slide into the black tube. It may be very tight. Spray it with WD40 and try it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 05-30-2016, 12:23 PM   #33
tstillman's Avatar
Originally Posted by Todouble View Post
Should be able to loosen that whee and pull the awning down on that side then tighten the wheel back up to hold it tilted down.
X2,. Both thumb nuts should be loose when opening the awning , just pull the side you want lowered. Then secure the thumb nut and you're all set. Y.
tstillman is offline   Reply With Quote
Old 05-30-2016, 03:10 PM   #34
Pickin' & Campin'
Here's a photo of the awning adjustment rod I made. While it looks to be as long as a picnic table in the photo, it's only 40" and these are really small picnic tables at this place.
I just hook at the roller area and pull back while standing directly by the knob to tighten. Super easy. I also use it to let it back out when putting the awning away so it doesn't 'pop out' when I loosen the knob.
ID:	109581   Click image for larger version
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-31-2016, 10:53 AM   #35
My knobs are always locked. When my dealer installed the new arm he adjusted it and said to leave it that way, it would be fine. I opened the awning after a rain and it drained fine so haven't messed with it.
Jim
George Bernard Shaw
Old 06-01-2016, 05:57 AM   #36
Jim
Does not seam right to me that the knobs would be tight,,,
when opening & closing ???
Old 06-02-2016, 10:49 AM   #37
And why not? They keep the rails from sliding when you don't want them to move. I have heard of people complaining about the awning opening while going down the road. Keeping the knobs and rails locked would help prevent that, right? I can't see where it can hurt anything.
Jim
George Bernard Shaw
Old 06-02-2016, 10:52 AM   #38
...Keeping the knobs and rails locked would help prevent that, right? I can't see where it can hurt anything.
Jim
Absolutely NOT!
Old 06-02-2016, 01:15 PM   #39
The OPs "Knobs & Rails" will NOT keep the Awning Roller from Unrolling going down the Road! The Roller MUST be secured from Turning,in case the Motor Fails! Youroo!!
Old 06-02-2016, 01:22 PM   #40
This will stop it from unrolling.
Name:	Alum tab for awning lock.JPG
ID:	109877   Click image for larger version
Name:	Alum tab, 3-8 x 1-2 ss bolt, washer & nyloc nut.JPG
ID:	109878   Click image for larger version
Name:	Awning lock top close up.JPG
ID:	109879   Click image for larger version
Name:	Awning lock turnbuckle.JPG
awning, dometic
