Old 07-18-2012, 02:34 PM   #1
How do I get wrinkles out of my awning?
I have a 19' awning that is wrinkled in the top third next to the trailer. I have taken the screw out of the awning rail and pulled it from from both sides but the wrinkles are still there. Any suggestions would be greatly appreciated.
Also. how do I get the title of my post to be in bold print?
2009 Rockwood 2701SS
2008 Tundra Crewmax 5.7
bob7794 is offline   Reply With Quote
Old 07-18-2012, 02:44 PM   #2
Rockinwood's Avatar
Lots of lotion!! LOL..JK, never had that problem, hopefully it is not permanent
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
Rockinwood is offline   Reply With Quote
Old 07-18-2012, 02:56 PM   #3
The awning is usually set onto the coach but slides in an out along the tube. The fabric may have shifted. If so, I would unroll the awning and carefully pull to one side or the other to align it so it's straight.
awjoker is offline   Reply With Quote
Old 07-19-2012, 05:35 AM   #4
M109Rrider's Avatar
Mine gets wrinkled but they go away after leaving it out on a hot sunny day
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 07-19-2012, 07:14 AM   #5
I agree with the m109rider i had the problem and just extended the awning out to the limit in the hot sun and it did the trick possibly you
are you winding it up while it is still damp and it is sticking as you roll it up ?
SALTY is offline   Reply With Quote
Old 07-19-2012, 07:58 AM   #6
After reading my reply, it wasn't clear that I would work with the TUBE end of the awning. It is this end that floats. As you already mentioned, the upper end uses a set screw. Leave it in place and work with the end that caused the problem.
Old 07-19-2012, 08:02 AM   #7
Extend the awning, let it set in the sun to warm, after about an hour, on the tube end, measure the distance from a common point to the edge of the awning material. Center the material on the tube. I drill a hole in the hem and install a 3/16" large head pop rivet in each end to make it stay centered. Have never had a problem with them wrinkling again.
Old 07-19-2012, 10:16 AM   #8
Terier's Avatar
There is a built in feature for threads with unread post(s) to display in bold font.
Bold font = unread reply/replies in thread
Regular font = all posts read - no new posts since last viewing
Terier is online now   Reply With Quote
awning
