Old 08-22-2016, 02:48 PM   #11
Or do this...works really well for me.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 08-22-2016, 04:09 PM   #12
If that was a CH751 key which is very common, maybe another camper has one you could use to unlock yours.
John Spear
RMCS (SW) USN Retired
2012 Ford F-150
Rockwood 2503s
debandi is offline   Reply With Quote
Old 08-22-2016, 04:22 PM   #13
You received many good suggestions, I'll just add this...
Lithium grease isn't a penetrate. It won't do much good freeing up frozen locks and will simply make the key slide in easier as you have already found out.
Try some sort of penetrate such as PB Blaster or even WD40. Work your second key in and out several times after spraying.
Should you decide to access the back side of the lock to try to move the lever by hand, make sure the second key you have is inserted so it disengages the tumblers in the lock.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-23-2016, 03:21 PM   #14
Bobaloo's Avatar
I agree with 5picker, also add a little lube to the arm after the door is opened. It only takes a little where the arm rubs the back side of the "jamb". Push the door in a little helps take pressure off the arm and will allow you to open much easier.
Bob
2013 Rockwood 2504
2015 Silverado 1500 Double Cab
Bobaloo is online now   Reply With Quote
Old 08-23-2016, 07:49 PM   #15
Thanks for the suggestions everyone. I was able to get the lock off from the inside. I may be looking into the slam latch approach. Thanks again!
Moellerdan is offline   Reply With Quote
Old 08-23-2016, 08:03 PM   #16
172av8r's Avatar
Well, there goes another $25 out of my checking account!!
2013 Rockwood Roo 23SS
2003 Ford F150 4.6L V8
172av8r is offline   Reply With Quote
Old 08-23-2016, 08:39 PM   #17
Left Coast
One caution...Slam latch doors are thicker than yours....you'll have to fabricate a 1/2" shim for the inside side of latch...
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 08-23-2016, 08:48 PM   #18
Toy-aholic
the downside of slamlatches is they're easy to get in to....just a thin screwdriver to push this up inside the latch & you're in.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A FOR SALE
2013 Crusader 335BHS TE FOR SALE
EXGMTech is offline   Reply With Quote
Old 08-23-2016, 08:58 PM   #19
CANADA FROG RALLY 2017
B and B's Avatar
Originally Posted by bob caldwell View Post
I'd buy slam latches, cut hole in doors, and move on....
Most outdoor kitchens I have seen do not have the depth required for slam latches.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 08-23-2016, 09:09 PM   #20
Left Coast
Mine fit closer together.....Brian, cut off wheel will make room! lol
lock
