Old 07-09-2015, 07:53 AM   #1
How do you clean your awning
I have tried the pour cleaner from the top of the TT on awning and roll it up. Let it set and open it up and rinse off but this just don't get it clean. What is you method for cleaning your awning ?
RRD1220 is offline   Reply With Quote
Old 07-09-2015, 08:01 AM   #2
Flybob's Avatar
I use a soft extendable auto wash brush with RV wash from a step ladder. The underside can be done without the ladder. Once dry I use an auto windshield washer ( foam pad side) on an extension to apply Aerospace 303 every 3-4 washings.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-09-2015, 08:16 AM   #3
Awesome on a Flat Microfiber pad. Top and Bottom! Have never (Treated) the awning. Youroo!!
Old 07-09-2015, 08:25 AM   #4
(Dry Huunday)
DreiHunde's Avatar
Yep...pretty much this!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 07-09-2015, 11:34 AM   #5
How Do You Clean Your Awning
I used half bleach and half water. I had a spray bottle that sprays upside down. I sprayed sections of the awning, let it sit a few minutes, then used a sponge mop and bucket, and wiped it off. It came out perfectly white.
purplebug570 is offline   Reply With Quote
Old 07-09-2015, 11:53 AM   #6
I'm with youroo.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 07-09-2015, 11:57 AM   #7
I may be wrong but I thought I read a tip here or somewhere else that one part bleach to 12 parts water worked well. As mentioned above, spray it on, let it set about 15 minutes and rinse it off. My memory of the 12:1 must be off a bit. Good luck. I will have to do mine, soon.
Duke is offline   Reply With Quote
Old 07-09-2015, 12:32 PM   #8
StlClay
My awning instructions said quarter cup bleach and quarter cup dish liquid in 5 gal water. I used soft auto brush wit extension pole....works great. I do after every trip. Make sure you can let it dry before rolling up. Both sides
2014 MiniLite with
Nissan Frontier
Stlcaly is offline   Reply With Quote
Old 07-09-2015, 02:50 PM   #9
this may come across as a dumb question, but; will a bleach solution hurt the colors on a colored awning?
JoeNanMinn is offline   Reply With Quote
Old 07-09-2015, 03:43 PM   #10
StlClay
The bleach never effected the color and will prevent mildew. The directions come directly from the manufactuer manual that my dealer provided with my trailer, purchased new.
2014 MiniLite with
Nissan Frontier
Old 07-09-2015, 03:53 PM   #11
Stank Bait's Avatar
"Make sure you can let it dry before rolling up. Both sides"
I can roll mine up dry and when it rains, it gets wet inside and mildews. Does yours stay dry inside? Cleaning lasts for a very short time because it rains a lot here.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 07-09-2015, 05:23 PM   #12
StlClay
I don't have much of a problem with that. I have seen where people modify litre soda bottles to fit overthe ends when it is rolled. I am sure somewhere on this forum you cn find instruction
2014 MiniLite with
Nissan Frontier
Old 07-09-2015, 05:35 PM   #13
B and B's Avatar
I use Full Timers choice Awning cleaner. Put this in a 2 gallons pump sprayer. Spray both sides and then roll up for a few hours. Scrub with a car wash brush and it is clean.
B and B is online now   Reply With Quote
Old 07-09-2015, 06:02 PM   #14
Canadian Member
I apply the bleach/soap solution with a window washing pad like this Unger Pro | 14 Inch Performance Grip Scrubber | Home Depot Canada on a long extension pole. After that, I use Hertel Plus and a Mr. Clean Magic Eraser to clean the remaining dirt and stains.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 07-09-2015, 06:10 PM   #15
Bleach and water work for me. No particular ratio.
larryo is offline   Reply With Quote
Old 07-09-2015, 06:47 PM   #16
Boso's Avatar
Use bleach with garden sprayer let sit then scrub with truck brush and long handle for good high quality awnings made from canvas soap and water only
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 07-09-2015, 07:05 PM   #17
Palmolive Oxy dish soap and water. Any mildew gets treated with a 5:
1 water/bleach mix and rinsed with water.
SkipnTerri is offline   Reply With Quote
Old 07-09-2015, 07:06 PM   #18
indybp57's Avatar
Another vote for the bleach/water solution. After spraying it down I roll it up for about 15-20 minutes, then unroll and hose it off. Works great.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 07-09-2015, 08:45 PM   #19
I use the siding mildew cleaner in the bottle you connect to a garden hose. Spray it on and rinse after 10 minutes.
kswing60 is offline   Reply With Quote
Old 07-09-2015, 08:56 PM   #20
asquared's Avatar
I've been known to use my automotive soap or bleach and water mix if mildewy. No issues.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
awning
