Old 03-07-2015, 10:01 AM   #11
Originally Posted by Rsharrer View Post
Got it! Found the valance screwed up into the cabinets and screws were tucked away and hard to find. The shade is attached with three screws that are now easy to access. Now I can remove it and take it in to be restrung. Thanks folks.
Re-string them yourself.
ID:	70902   Click image for larger version
ID:	70903   Click image for larger version
Old 03-07-2015, 10:17 AM   #12
X2 on restringing them yourself. Pretty easy actually. I brought a piece of the cord to get the right diameter to a fabric store and they had it. I used the drawings O.C. provided above to do mine years ago. Might as well learn how because you might need to do it again. Here's some links for you:
http://www.discoveryowners.com/DayNightCompile.pdf
Old 03-07-2015, 04:11 PM   #13
Smile
Gljurczyk- did the valance or the shade fall off? Our day/night shade would come down when we are on the road and so our pretravel check list includes pulling that rear day/night shade down.
If the shade falls by itself, the string tension is to loose. Each string is attached to the wall on a plastic thimble/spool. Loosen the thimble/spool screw slightly and turn the thimble (or spool) 1/4 turn in the direction which tightens the string. Then tighten the mounting screw of the thimble. This will provide the resistance to keep the shade up. Repeat an additional 1/4 turn if you want more resistance.
l001952119 is offline   Reply With Quote
Old 03-07-2015, 04:49 PM   #14
Witch Doctor's Avatar
The shade pulled my thimble right out of the wall, it's only 1/8" thick. had to move it over an 1"
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
