Old 01-30-2016, 03:57 PM   #1
How do you repair window shade?
The large day/night shade at the rear of the fifth wheel will not stay up
The two center strings are tight, but the ones on the sides are loose.
Repair or replace?
Millerx5 is offline   Reply With Quote
Old 01-30-2016, 04:09 PM   #2
Platokidd's Avatar
Watched a buddy of mine and his wife restring one. PITA but they did it. Labor intensive tedious work and a few choice 4 lettered words along the way.
Ever see an old couple bickering
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 01-30-2016, 05:12 PM   #3
fonzie's Avatar
https://www.google.ca/webhp?sourceid...ade%20restring
Fonzie
Old 02-01-2016, 10:16 AM   #4
Good links from fonzie. Alot cheaper to repair than replace. I've done a couple and it really isn't that hard.
Old 02-01-2016, 10:42 AM   #5
AquaMan's Avatar
If the strings are just loose and not broken, loosen screw of the bottom retention point, pull string tight, and screw back in.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 02-01-2016, 11:16 AM   #6
DAISY BOYKIN's Avatar
Restring Night & Day Shades.
Takes a little while to restring night & day shades. But if you attempt to
restring, make sure you order the largest string available for the job. I ordered a spool of string size 1.2 MM from FIX MY BLINDS, it is too small, order the next size larger which is 1.6MM. The color of the string is Alabaster that is used in the Rockwood RV. If you order kits, you will get
replacement "EYES" or guides and springs. I tied the new string to the old string and pulled it through all the holes. Just lay down on a bed or large table, takes about 1 hour to restring a blind.
Good luck
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 02-01-2016, 11:25 AM   #7
bubbles's Avatar
If these are just vanilla pleated shades just take up the slack on each end by putting a few more wraps on the wall mounted spools. No need to remove spool just pull string taught and wrap.
Old 02-01-2016, 11:40 AM   #8
My wife & I have done three of them. Once you do the 1st one it's easy. She had a large needle that we threaded with the string. Don't pull old string out. Follow where it goes with the new string. It took the two of us. There's a difference between the big shade and the smaller one. If you can go online a try to get instructions it does make it easier. Good luck.
Pipeman is offline   Reply With Quote
Old 02-01-2016, 11:59 AM   #9
jeff64's Avatar
Check out the you tube video
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 02-01-2016, 12:22 PM   #10
I found a local person who works out of her house. Easy and reasonable. Dealer referred me to her
Harkerr is offline   Reply With Quote
Old 02-01-2016, 12:30 PM   #11
shade repair
Google "the dirty blind man". Sounds weird, but you find what you need ( materials and instructions including a video)
blc
bruceconley is offline   Reply With Quote
Old 02-01-2016, 12:48 PM   #12
LOL, I asked my dealer if they would do it and they flat out said 'NO". When they found out we did our own, they asked if wanted to do a bunch for them. We flat out said "NO".
Old 02-01-2016, 02:24 PM   #13
We broke a string on ours and I called the manufacture to see if they had a repair kit available. Repair kit cost $15 or you can send in the blind to them and they will repair it for $15. Choice is yours
RRD1220 is offline   Reply With Quote
repair
