Old 06-17-2014, 02:44 PM   #1
how to clean my power awning
on my old TT I had a manual awning I could put out and lower down to wash it... our new tt came with a power awning... I don't see any way to lower it to get a brush on the top side... am I missing something or do I need to get a tall stepladder to be able to clean it? thanks !
steveh326 is offline   Reply With Quote
Old 06-17-2014, 02:54 PM   #2
Cleaning the fabric has been discussed in here previously. Some posters had some pretty invative methods to clean them up without too much elbow grease needed. They also mentioned that using a long handled brush during the roll up worked out well.
Look it up, there were some good examples with sucess.
Old 06-17-2014, 03:22 PM   #3
DougP47's Avatar
I use a power washer. Care must be taken not to over pressure and stay in one area to long. Been doing it for 3 years and have not damaged anything yet.. I tried using a brush and noticed the awning was showing wear till I changed my cleaning method. Start out with wide spray pattern then adjust as needed.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 06-17-2014, 03:25 PM   #4
thanks still kickin, but just to be clear... I have a brush and cleaner no problem... my issue is that my electric awning is always at full height and I can't reach the topside unless I were to use something like a 10' stepladder. I don't see any way to 'unhook' any of the joints in the awning arms to lower it so I can reach it even using my 8' handled brush.
Old 06-17-2014, 03:27 PM   #5
You will have to clean the upper top side from the roof with a brush. That's the way the professionals do it in FL.
Old 06-17-2014, 03:34 PM   #6
Seriously, look for that thread. As I recall one guy found a cleaning solution that worked. He applied it and rolled up the awning. You have to think out of the box on this one. It was a GOOD thread.
Old 06-17-2014, 09:06 PM   #7
Triguy's Avatar
I like LA's Totally Awesome for the awning. The process I use is to slightly dilute the concentrated Awesome, spray it on the underside (make sure to wear safety goggles and old clothes), climb on top of my camper and spray it on the topside of the awning and spread with a mop, roll up and let it sit for 30 minutes. Unroll the awning and wipe off top and bottom with a mop and water. You might need to use a scrub brush for stubborn stains. Rinse top and bottom with a hose when done cleaning. Let dry.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-17-2014, 09:07 PM   #8
HemiCab's Avatar
Here is the jest of the post I found about the awning.......
Awning mold
I searched and noticed that there were multiple people that have had issues with the brown spots on the underside of their awnings. I had it too and tried everything...powerwashing, tilex with bleach, awesome, dawn and vinegar. I was about to give up and called House of Camping and asked if they knew any magical solution to get it off. They told me 1/2 cup of bleach, 1/4 cup white vinegar, and 1/4 cup hot water. Put in a spray bottle an spray on the spots. Let it air dry, do not rinse or scrub. OMG-It worked!!! After it was lall off, we gave it a good rinse.
Hope that helps
HC
2008 Dodge Ram 2500 QC CTD 4x4
2014 Cherokee 284BH
Equalizer 1,200/12,000 WDH
TST 507RV TPMS
MaxBrake BC
HemiCab is offline   Reply With Quote
Old 06-17-2014, 09:31 PM   #9
themounties's Avatar
I just use a 6 footer, the same as hemicab said, but I'm gonna try it with the hot water next time, I had dw stand inside and roll awning in a little bit and I would give it a good spraying with the bottle, and then hose it off real good.
themounties is offline   Reply With Quote
Old 06-17-2014, 09:37 PM   #10
Herk7769's Avatar
I use Westley's Bleche Wite and a sponge mop with a brush on the front.
Amazon.com: BLECHE WITE TIRE CLEANER 64 OZ.: Automotive
QUICK work top and bottom. No mold in seconds.
ID:	55650   Click image for larger version
ID:	55651   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-17-2014, 10:17 PM   #11
mark0224's Avatar
Glad somebody brought this up was just getting around to tackling this one
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-17-2014, 10:23 PM   #12
Fulltime family RVer
We did very to close to what Triguy said- used Awesome only we diluted it using my father-in-laws pressure washer. We were able to spray the top and bottom from ground level. We rolled it up for about 30 minutes. Had I had a brush on a handle, we would have used that for some of the stubborn spots- but we didn't. He then used the power washer with just water to rinse it off. He was able to do everything from ground level. It looks pretty nice.
Old 06-18-2014, 07:36 AM   #13
cpaulsen's Avatar
I use the same method on my electric as I did om my manual one. Spray bottle....little bleach.....couple good shots of Dawn dish soap(helps the bleach stick) and the rest of the bottle of water. Spray it on underneath.....roll it up for about 20 to 30 minutes. The top gets cleaned at the same time when it roll up. Unroll....hose it off. Mine comes out very clean using this method. No special stuff to buy.
cpaulsen is offline   Reply With Quote
awning, power
