Old 01-18-2020, 02:55 PM   #1
Isata 5 door lock
I have a 2019 30FW i have used a lot have 75K miles on it with only little things going wrong. I have a problem with the entry door lock the keyless entry system quite working. The factory sent a new unit and it still doesn’t work I don’t think it is getting power. I have checked and cleaned the contacts on the hinge side of the door. The light on the panel do not light up and i get no power at the contacts with a multi meter with the door open. Is their a fuse somewhere or ???or does someone have a wiring diagram.
Zoey is offline   Reply With Quote
Old 01-20-2020, 09:07 AM   #2
Commercial Member
ES_FR's Avatar
Zoey,
We would be happy to assist you with your 2019 Isata 5. Please contact Dan Dobecki in our Customer service department through the following personalized and direct link: http://www.dynamaxcorp.com/DirectSer...51079722091351.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 02-17-2020, 09:15 PM   #3
Dynamax Isata 5 FW
van_fl's Avatar
Door fuse
On your i530fw there is a in line fuse under the steps, by the step control board.
van_fl is offline   Reply With Quote
door, lock
