Kwikee Steps Not Working - Looking for 6 amp fuse
Hi all. MY Kwikee steps on 2005 Georgetown have stopped working. Here are conditions:
1. Steps do not retract under any circumstance, ignition on, door closed, etc.
2. Turn on switch and the understep light goes on with door closed
3. Open the door and the light goes off
4. Motor works (applied 12V in both directions and it works)
I have located 25 amp fuse and 5 amp fuse in house battery compartment but the drawing from Kwikee shows another 6 amp fuse somewhere. Prior to replacing a controller module I'd like to check that fuse but cannot figure out where it is located.
Does anyone know where I should look to find the 6 amp fuse?
Thanks,
