Old 12-10-2018, 04:33 PM   #1
Leaking LCI entry door window
I went out to trailer today to check things after a substantial rain storm. Found the “new” pressed window in the entry door leaking down the inside of the glass then continuing into the door between the window and the inside trim.
I had never seen this new design snap fit before. Fortunately, I found 2 pages of technical info about the pressed design. So, I squeezed the inner and outer frames together at the top and heard a distinct “click”. Since it is about 40F and drizzling, i decided to not disassemble anything and hoped the click would work.
No joy. I also do not know how long the fastener had been un-clicked and if there are others that are broken. Ths is a window with no screws. It appears as if there are 14 to 16 plastic fingers that are supposed to keep the window gasket tight.
See this link: https://www.lci1.com/assets/content/...CD_0002272.pdf
Any ideas?
Most coincidences appear to be carefully planned.
There is nothing more permanent than a temporary solution.
Jeffjeeptj is offline   Reply With Quote
Old 12-10-2018, 04:40 PM   #2
More lippert junk . they keep putting it out, Rv manufactures keep buying it and owners keep dealing with the cheapest lowest quality junk available .When the weather clears i would at least silicone the edges
MR.M is offline   Reply With Quote
door, leak, window
