Old 01-04-2015, 05:01 PM   #1
Locked out!
Hello I'm new to the forum and need help with an issue I have. I just bought a 2006 Cherokee Lite 28a+ last may and unfortunately I have misplaced the keys to the door and storage compartments. The dealer I bought it from is almost 2 hours away from me. How would I go about getting replacement keys or do I have to replace the door and compartment locks or can I get keys to open my existing locks and can my local dealer help me with that? Thanks for any help I am able to receive.
muzykman819 is offline   Reply With Quote
Old 01-04-2015, 05:09 PM   #2
Flybob's Avatar
According to my dealer, the storage compartment keys are not unique to your RV. Also one of the door locks is unique and one is not. So you may be able to just order replacement keys.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-04-2015, 05:14 PM   #3
Ok thank I'm going crazy trying to find the keys and I'm just not having any luck my cat has knocked keys off the wall in the past and likes to hide them.
Old 01-04-2015, 05:20 PM   #4
R&J Silverback's Avatar
got locked out myself, called locksmith the first guy wanted to drill lock out and I said no!! not on y new unit, called and got a good locksmith took him all of 2min to open door then took lock out and they made a new key.
Ron & Jan and black dog(Bella)
2011 Ram 3500 crew cab 4x4, 6sp manual,342's 8ft.bed
2014 CC Silverback 29ik
R&J Silverback is offline   Reply With Quote
Old 01-04-2015, 05:24 PM   #5
That sounds good it was either going to be a locksmith or try the dealer. Just not sure which one is more expensive or if the cost is about the same either way.
Old 01-04-2015, 05:29 PM   #6
Flybob's Avatar
Try this:
Compartment keys
Replacement Key for Compartment Hardware - RV Designer L200 - Compartment and Hatch Hardware - Camping World
TST Tire Monitors
2 100W solar panels
Old 01-04-2015, 05:34 PM   #7
Thanks for the link I'm going to order one or two or 3! LOL! Thanks for all the advice of everyone as well. :-)
Old 01-04-2015, 05:39 PM   #8
asquared's Avatar
If you know the number on your door keys you can order them online. As stated above, I'm willing to bet your pass thru uses a ch751 key. These are readily available online.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-04-2015, 05:49 PM   #9
Yes that is the number on the compartment keys unfortunately I do not remember the number on the key that unlocks the deadbolt and the other lock on that door.
Old 01-04-2015, 06:11 PM   #10
caper's Avatar
Do you have AAA coverage? The supply locksmith for lock out service.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-04-2015, 06:14 PM   #11
Unfortunately I don't but I am now SERIOUSLY thinking about getting it! LOL!
Old 01-04-2015, 06:18 PM   #12
Oaklevel's Avatar
Did you lock both locks on the main doors?? If not (I forget which one I always have to ask the dealer which one to lock so he can get in.) the dealer may have a master key but if you locked both locks that will not work. If the compartment locks are the CH751 they will definitely have a key.
Good Luck.....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 01-04-2015, 06:24 PM   #13
Flybob's Avatar
If it is the standard door lock, the top one is universal by model / brand, the lower one is unique and you will need to know key number.
TST Tire Monitors
2 100W solar panels
Old 01-04-2015, 07:24 PM   #14
The deadbolt is not locked just the regular lock.
Old 01-04-2015, 07:27 PM   #15
But one key unlocked both deadbolt and regular locks.
Old 01-04-2015, 07:46 PM   #16
Ford Idaho's Avatar
Mine is like that one key for the entry one for the basement and the rest were 751.
Old 01-05-2015, 11:02 AM   #17
WestCoastRV'er's Avatar
if you know the key number, you can order from here. I just ordered 2 new keys as someone stole one of my sets from my Jeep. Going to put a set in a magnetic key box hidden somewhere.
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys
Best of luck
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 01-05-2015, 11:36 AM   #18
Kaadk's Avatar
If I remember correctly, the regular lock should be able to be opened with the master, and it's the deadbolt that you need the unique key for. Your dealer should be able to get you in in that case.
Course, this still doesn't solve the problem of not having the keys on hand. At some point, you'll still need to either get a set made or find where the cat hid yours.
Old 01-05-2015, 12:34 PM   #19
Witch Doctor's Avatar
On my door I have one key for the master and dead bolt. One key for all the hatches keyed a like #5, And one key for the outdoor shower door. My key say's GOBLE LOCK with a # on it for the door and dead bolt.
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-05-2015, 12:35 PM   #20
I found my keys! THANK GOD! My wife's cat got ahold of them and dropped them between the washer and dryer in my basement. :-)
