04-09-2018, 12:36 PM
low corner on awning
when we took delivery of the rv, we didn't notice that even tho the awning
worked; when extended the front corner is way low.
it sits right at face level,
is there any way to raise the extended height?
its an automatic unit
thx
04-09-2018, 12:52 PM
Grammar Pedant
Originally Posted by akronite
when we took delivery of the rv [...]
What RV? The more you share with us, the more help you'll get. Many RV features are the same across lines; some RV features are specific to a brand or model.
On my trailer with an electic awning, the vertical connection arms of the awning can slide up and down to raise or lower the awning. This allows you to make it flat, angled, or uneven from side to side.
Yours may work the same way.
Check out 0:37 of this video to see what I'm talking about :
Former RV: 2018 Rockwood Mini Lite 2504S
04-09-2018, 12:57 PM
Profile says 2017 Sunseeker motorhome.
04-09-2018, 01:11 PM
If you have the gas lift cylinders on your awning arms, it is possible that the front one is damaged and is not supporting the front corner of the awning. Move the end of the awning up and down by hand. There should be some resistance. Start with the rear working one. If the front does not feel the same, that could be the issue. Easy fix.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Grammar Pedant
... and the post and signature in this thread say nothing. Again, my recommendation is probably pretty solid in any forum you visit (not just here, not just RVs): the more information you provide, the more help you will receive. If you require people to click around and investigate, you still may get help, but may not get as much. Not sure if this is really that controversial, is it?
Anyway, I didn't intend to chastise the OP, just asking what his RV is. Again, I always recommend that people put information in the actual posts. I also tried to provide some decent help by pointing him to a height adjusting video. I don't know if this is how sunseeker MHs work or not.
Good luck.
04-11-2018, 08:22 AM
It's also a good idea to search here before starting a new thread !!!
04-11-2018, 08:29 AM
A picture is worth 1000 words.
04-11-2018, 11:21 AM
low awning
wow, sorry it's taken soo long to reply, whew
so it is a carefree model, on my 2017 ts2390 forest river, transit.
nothing special,
I will get a picture up probly tomorrow, its stored today,
I did look here for similar posts, but wasnt satisfied that any applied to me, wolverine!
did you see one i should have noticed,
I dont read or post very often, then, even when i mean to; I'll forget to and do something else
i'll look forward to more reactions, I mean help, and I'll show a photo
thanks for now
04-12-2018, 07:54 AM
nothing special,
thanks for now
My guess is you just have to adjust yours !!!
04-12-2018, 08:17 AM
Post #4 is where to start.
check you lift gas cylinders on each end to see if they are lifting the arms up to where they should be. Cold weather will make them 'sluggish' and as the air temp heats up, they will work(push out) better.
Is the front arm sliding up and down (pull and push up and down when awning is out) smoothly or binding?
Is the 'lock down' (to hold awning down at an angle) too tight and needs to be loosened?
Brother Les
04-12-2018, 08:25 AM
thx
See the comments I made bold/red above.
What does this mean?
04-12-2018, 08:30 AM
thx
imo, it means that the gas cylinder is not pushing the awning arm up (when awning is fully out) and is letting the awning arm on that side drop down due to the weight on it.(when awing is fully out)
Brother Les
04-12-2018, 08:36 AM
Possibility the Large Black Plastic Nut is to tight on the front ???
04-12-2018, 09:00 AM
My awning has an adjustment to drop one corner in order to dump rainwater. You can drop either corner depending on what you like.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
04-12-2018, 09:05 AM
Maybe OP is MIA ???
LOL !!!
05-15-2018, 09:15 AM
well having trouble posting pix, so check them out in profile
thx
05-15-2018, 09:20 AM
thx
This post gives step-by-step instructions on attaching photos to your posts.
http://www.forestriverforums.com/for...html#post49621
