Old 05-27-2019, 08:11 PM   #1
Main Door Seal Replacement
I need to replace the peel and stick foam seal/gasket around both doors on my model 2502 Rockwood.
Does anyone have a better recommendation than the standard or what I believe to be the standard 1/8th inch thick by 5/8th inch wide peal and stick foam tape? I get large amounts of dust in the trailer due to desert camping here in Nevada. I replaced the foam tape 4 yrs ago with the closest I could find: 3/8 by 1/2 inch vinyl weather stripping foam tape by AP products and it needs to replaced again. If someone knows of a better product I would appreciate it!
Thanks for your time.
Rockwood2003 is offline   Reply With Quote
door, replacement, seal
