Old 05-05-2016, 11:59 AM   #1
Maxxair Cover on vent with fan
I installed the Maxxair vent covers on three vents no problem but the bathroom vent has a fan and I don't see a way to access the bracket screws. Does this require removing the fan in order to install?
Darrell & Kathy
2018 Oliver Legacy Elite II
2013 Ford F250 6.7 Diesel
2013 Flagstaff 8528IKWS 5er (Sold)
B&W Companion Slider (Sold)
wdw0528 is offline   Reply With Quote
Old 05-05-2016, 12:57 PM   #2
Nope. Follow the same directions as before.
David 01 is offline   Reply With Quote
Old 05-05-2016, 01:14 PM   #3
TURBS's Avatar
You have to remove inner trim panel and screen to bolt all the way through.
I used the alternative method of drilling pilot hole and just using the screws that screwed into housing
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "2"
2015 nights camped "34"
Old 05-12-2016, 02:43 PM   #4
Thanks Turbs.....just installed it yesterday. Had to remove the fan from the top side and a shroud cover on the bottom side. With those removed I could reach the back side of the frame for securing the nut and washer.
Name:   ImageUploadedByForest River Forums1463082189.196354.jpg
Darrell & Kathy
Old 05-12-2016, 02:55 PM   #5
Frog-Toberfest Organizer
Do these help? My 320A Vengeance only has the bathroom vent and fan. Would it even be worth it to install one of them?
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
Electra glide is offline   Reply With Quote
Old 05-12-2016, 02:58 PM   #6
They help in the fact that you can use your fan raining or not.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-12-2016, 02:58 PM   #7
I go RV'ing not Camping
jgourlie's Avatar
I install a cover on all the vents that I have in my trailer. The biggest help is for when it's raining, no need to close the vent.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-12-2016, 03:01 PM   #8
Electra Glide I was experiencing some leaking in the vent covers.... apparently cracked from weathering. The maxxair covers solved that problem AND I can now get better ventilation in the camper as I can now leave vents open more often.
Darrell & Kathy
cover, fan, vent
