Old 05-29-2019, 01:58 PM   #1
My awning is blowing fuses
Hi looking for some help. I have a 2014 Forrest River surveyor cadet. We went to retract the awning today and blew Thur 10 15amp fuses before it finally closed. I finally had to hold the retract at 1-2 second intervals to not blow my last fuse. Has anyone else experience this? Thank you in advance
Bmeader is offline   Reply With Quote
Old 05-29-2019, 02:02 PM   #2
rp53's Avatar
yes i have turned out the hot wire inside the extension arm hinges has over time rubbed a bare spot in the wire and it was shorting against the extension arm did a little rerouting and some good electrical tape good as new
2017 Micro Lite 21FBRS
2017 GMC Sierra double cab Z71
rp53 is offline   Reply With Quote
Old 05-29-2019, 02:03 PM   #3
Do you see the awning rolling up unusually crooked or binding?
Fuses blow because of short circuit or unusually high current draw.
A shorted circuit typically causes a fuse to blow immediately.
High current draw allows the load to run a bit, then blow the fuse.
Your awning motor may also be bad or have gotten water in it.
There are ways to test current draw on a circuit with the proper tools.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 05-29-2019, 04:08 PM   #4
Thank you I will look into that. Is that wire on the arm closet to the front?
Old 05-29-2019, 04:18 PM   #5
Iwannacamp's Avatar
Prolly a stupid question.... I assume the locking nuts are loosened? I would get some silicone spray and lube all the slides and connections. FWIW
Is there a way to pin the motor and move the arm by hand to feel for binding?
2017 Puma 297RLSS
Old 05-29-2019, 05:00 PM   #6
rp53's Avatar
The power cable to mine (21FBRS) is cradled inside the arm the pinch point is where it hinges
Old 05-30-2019, 08:45 AM   #7
Yes. It is a common problem. I am using a 20 amp fuse at the advice of my RV mobile tech. The best solution is to find a resetable fuse. Be careful when you get near the rig and don't leave the button pressed too long.
ppine is offline   Reply With Quote
Old 06-02-2019, 03:56 PM   #8
Thank you for the help it was worn down wires I taped them and everything is great.
awning, fuse
