Old 06-16-2013, 07:42 PM   #1
Send a message via AIM to jk31668
need info/help on my dometic power awning
i have a 2010 sunseeker 3100 ss and just noticed that 2 of the screws on the top rear bracket that holds the awning up were out about a half inch. i tried to screw them back in and found that they dont really tighten good. like they are stripped. i also checked the other 2, plus the ones on the front bracket and they are almost the same. so, any idea what i should do? a larger screw probably wont go thru the bracket hole. any idea how long these screws are? thanx
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 06-16-2013, 08:04 PM   #2
Depending on what is on the inside of the camper, you might be able to drill on thru and put a metal plate and use a regular ss machine bolt/nut.
