Old 04-05-2016, 09:42 PM   #21
gmann55's Avatar
How do you know witch way to move it?
gmann55 is offline   Reply With Quote
Old 04-05-2016, 10:02 PM   #22
Measure from each end of the roller to the material and make it the same on both ends. Once you get it centered, run it in and out a couple of times to make sure the arms close completely.
Old 04-06-2016, 08:15 AM   #23
Wolverine 1945's Avatar
With the old style Manual Awning you needed 2 Men & a Step Ladder !!!
With the Power Awning,,, you may need 2 Step Ladders ???
Wolverine 1945 is offline   Reply With Quote
Old 04-20-2016, 05:51 AM   #24
Do you just pull like there's no tomorrow? Or is there a trick to it?
My awning is 21 or 22 feet and I haven't figured out how to seemingly effect the positioning.
My awning is about 21 ft as well. The first year of owning the camper the tube itself bowed a little from the bouncing while going down the road. I had an awning support installed and that has helped. However, when I retract the awning sometimes the fabric will wrinkle and the rear awning beam will not close all the way. I've been trying to figure out adjusting it as well without creating more issues. Have you had these issues?
OKI Marine is offline   Reply With Quote
Old 04-20-2016, 06:56 AM   #25
Where we camped we had a step ladder,,, so I would have to clime up and persuade the arm to unlock in,,, also @ times I would have to use the ladder to unlock the arm !!! Arms MUST be locked before traveling !!!
Old 04-20-2016, 07:25 AM   #26
I thought the subject is Elet.Awning? There are No locks on the arms! Youroo!!
Old 04-20-2016, 07:26 AM   #27
Have found out you have to center the material on the tube. It is a PITA job requiring 2 people, at least one ladder and deploying the awning. Once the material is centered on the tube, I pop rivet both ends thru the side hem.
Name:	Pop Rivet in Awning.JPG
Old 04-20-2016, 08:17 AM   #28
You could be right Youroo,,,
it sure sounded a lot like our old manual one !!!
Old 04-20-2016, 08:42 AM   #29
I'm talking about electric ones. That's what I have, hince the word retract in my post
Old 11-13-2016, 09:41 AM   #30
gmann55's Avatar
OC. Are you building any awning deflapper poles for a@e awnings. Any pictures of what you have made?
awning
