Old 04-04-2016, 12:40 PM   #1
Need to adjust my awning
I have an automatic awning on my RV. The problem is that it doesn't roll up without getting the vinyl fabric skewed. In other words, it doesn't roll up evenly but instead it wrinkles the fabric as it goes in.
I want to adjust this so that the roll on the RV matches the roll on the outside "barrel", without twisting or skewing the fabric. This will of course require me to re-roll the fabric on either the RV or the outboard barrel. I am not sure which one comes off or the procedure to do it right. I am under the impression that it is all under tension, but unsure how.
Is anyone aware of a YouTube video on doing this, or some instructions somewhere?
MOODMAN is offline   Reply With Quote
Old 04-04-2016, 12:44 PM   #2
bubbles's Avatar
Extend it fully and center it on the roller. Some put a pop rivet (through the fabric and roller) in one end or the other to prevent off center creep.
Old 04-04-2016, 01:22 PM   #3
Always Learning
I keep pulling mine, but I can't get it to center up. I need to find a FRF'r and work together to do it.
Sort of wish I was going to Goshen!
Old 04-04-2016, 01:46 PM   #4
TURBS's Avatar
Almost does take two people.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-04-2016, 02:46 PM   #5
But that's just the thing. I don't know how to center it on the roller. If it's under tension, then if I take off the fabric, it might snap on me. Not sure how it's all rolled up, so I want to do it without getting myself in a situation where I take it apart and can't put it back together.
Old 04-04-2016, 03:10 PM   #6
Always Learning
People talk about extending the awning and literally shifting it on the tube without taking anything apart. (At least, that's what I believe that I understand.)
Old 04-04-2016, 03:38 PM   #7
TURBS's Avatar
Yes! It can be shifted with awning extended.
Old 04-04-2016, 03:39 PM   #8
Left Coast
X2....otherwise, how would you grasp it..
Old 04-04-2016, 03:43 PM   #9
Left Coast
Use ratchet straps from upper end of arms to a pick-up, if you have one, parked out a little from the awning....Don't completely un-roll awning to where it becomes tight..
Old 04-04-2016, 03:46 PM   #10
Always Learning
Do you just pull like there's no tomorrow? Or is there a trick to it?
My awning is 21 or 22 feet and I haven't figured out how to seemingly effect the positioning.
Old 04-04-2016, 03:51 PM   #11
TURBS's Avatar
Just pull on the side you want it to move to, just give it a lil jerk.
As ocw Sadie don't completely un roll it.
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-04-2016, 04:30 PM   #12
Left Coast
Maybe need to slime up the roller track with a little Dawn dish soap
Old 04-04-2016, 04:59 PM   #13
Spray some silicone in both grooves on the tube and make sure you try moving the material when it is warm.
Old 04-04-2016, 07:32 PM   #14
Thanks for this thread. I need to try to do the same.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is offline   Reply With Quote
Old 04-04-2016, 07:35 PM   #15
Left Coast
After getting it straightened out, make sure you put a pop rivet through material into roller out at the double folded edge (hem) on the end of material
Old 04-05-2016, 11:23 AM   #16
Always Learning
Thanks fellas, I'm going to give it a whirl.
Thanks MOODMAN for asking the question. Sorry about the sorta-hijack.
Old 04-05-2016, 11:55 AM   #17
My pleasure. I wondered if I was the only one with this issue.
Old 04-05-2016, 12:01 PM   #18
A32Deuce's Avatar
I used the anchor poles, ran it all the way out then ran the poles up to put slack in the material, tied down with the slack still in and .pulled it over
A32Deuce is offline   Reply With Quote
Old 04-05-2016, 06:42 PM   #19
NMWildcat's Avatar
My electric awning is only 18 feet but I have had to recenter several times over the years. I find it easiest to extend it out, then I stand on a box and push in the middle of the tube to alleviate the tension (an inch or two, like when the wind grabs it sometimes and makes the fabric billow), and the wife pulls the fabric from the side to center it. Also you'll notice most tubes sag in the middle slightly so by my pushing it also takes that little sag out to help the fabric slide in the rail. Hope this helps and good luck!
Old 04-05-2016, 06:48 PM   #20
Once you get it centered, pop rivet both ends thru the hem and it will stay centered.
awning
