Old 12-08-2013, 02:17 PM   #1
New door hard to close
We took our new Vengeance out for the first time. The front door seems to stick, meaning you have to slam it to get the locking part to close. Or hold the handle open then close it. The rear door doesn't have this problem. I have looked all over the area where the lock mech. is and can't see a high part or wear marks. Should we mention it to the dealer when we go back for some other PDI fixes we need done or is it normal? Everything else worked great except the shower head shattered the first time we used it. Thankfully wal-mart had a replacement!
melissa16 is offline   Reply With Quote
Old 12-10-2013, 10:26 AM   #2
Always Learning
I think if one door works and the other doesn't, then it is definitely something for the dealer to look at. I'm very anti-door slamming in any situation.
Not a Vengeance, but our door is hard to close and it makes me crazy. My dealer was a big fat zero, so I'm hopeful that the factory does right by me since it is back for other stuff.
Old 12-10-2013, 11:06 AM   #3
AquaMan's Avatar
Check all around the door for any type of wear. If possible, have someone close from the outside slowly while looking on the inside for any contact points. Find the point of any resistance and while "working the door" at the point, check for any movement in the frame. A bind on the hinge side could cause a door to stick also.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 12-10-2013, 11:22 AM   #4
Campfire Master
If the door doesn't seem to be rubbing anywhere on the frame, then it's possible all you need to do is adjust the striker. Loosen the screws and slide it very slightly towards the outside and tighten. May have to move it again, just a little until it closes easily.
John
AVid is offline   Reply With Quote
Old 12-10-2013, 11:44 AM   #5
5 hole's Avatar
I have found when I put the stab jacks down and 'lift' the trailer a bit to achieve level that my door would go out of square and be hard to close. If I back off on the stab jacks a bit, it would help...
5 hole is offline   Reply With Quote
Old 12-10-2013, 01:02 PM   #6
Always Learning
That's a good point, but not quite what you're saying - you shouldn't use the stabilizer jacks for leveling.
If you're using the stabilizer jacks for leveling, it can cause twist to your camper which can cause doors to jamb such as this.
Old 12-10-2013, 01:08 PM   #7
RKR
RKR's Avatar
X2
My first trip out I put just a little lift with my stabilizers. The first time we used the bathroom the door wouldn't latch. When we were about to leave and the jacks and stabilizers were up I went inside to secure the door so it would bang around while driving and it closed securely. My rookie move.
RKR is offline   Reply With Quote
Old 01-14-2014, 10:34 PM   #8
Dear Melissa 16
I had the same issue on my new 2103 georgetown xl 378
Not only was the strike plate too high I had to grind a little on the outside door frame so I could lower the plate more than what it would go. I also had to pry the strike plate out a little. The bolts on the locking mechanism was hitting the inside of the strike plate.
It really didn't show much wear where it was hitting.
I can take pictures if you like and send them to you.
After I adjusted the strike plate the door works great whether the jacks are up or down. No more slamming or pushing the door to make sure it latches closed.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
door
