Old 01-29-2019, 10:51 AM   #1
No awning lights
Hi .. thank you Terri for your instructions .. my awing lights will not turn on.. they work.. but wonít turn on with my control panel.. I followed the wires ck fuses by door .. does anyone know what I can do..?
Thank you
RHannon is offline   Reply With Quote
Old 01-29-2019, 10:56 AM   #2
Flybob's Avatar
If you have a remote for your lights and they were turned on/off with the remote, they need to be turned on/off with the remote on some units. Same with the manual switch.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-29-2019, 12:50 PM   #3
Swing lights
Hi Flybob .. we do not have A remote.. could there be. Fuse we need to ck.. or could our control panel be a problem.. we checked the outside wires .. Tu
Old 01-29-2019, 01:38 PM   #4
Who Dares, Wins
doc73's Avatar
Can you jump the wire and bypass the switch? if they light you know your switch is bad. If they do not start looking at places where the connections could have corroded from water or pinched wires.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 01-29-2019, 02:50 PM   #5
Awing lights
Hi doc Tu ..we jumped from the battery to the wire ., the lights lit.. but we cannot turn them on from our control panel ..
Old 01-29-2019, 03:00 PM   #6
Is your control panel the newer touch pad/screen or do you have old school rocker switches?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 01-29-2019, 04:36 PM   #7
Awing lights will not turn on from control pad
I have a 2017 forester the awing lights will not turn on from our control panel.. no remote.. but lights do work when we tested them.. does anyone know if the control panel comes off.. and could there be a lose connection behind the panel.. any other fuses we should ck ... Tu
Old 01-29-2019, 07:25 PM   #8
Who Dares, Wins
doc73's Avatar
Is it a touch pad or a rocker switch?
2015 ChevyHD D-Max
Old 01-30-2019, 12:13 AM   #9
Hi doc it’s the new touch pad ..I was thinking if I take it off I could ck behind it but not sure how to take it off.. I also ck the wires from the lights and followed them down to under the Rv .. didn’t see any problem.. but can’t see where they go from there..
Old 01-30-2019, 06:46 AM   #10
Who Dares, Wins
doc73's Avatar
Hi doc itís the new touch pad ..I was thinking if I take it off I could ck behind it but not sure how to take it off.. I also ck the wires from the lights and followed them down to under the Rv .. didnít see any problem.. but canít see where they go from there..
I'm not sure what kind of servicing you can do on a touchpad other than replacement. If you can remove the face and get access to it you might be able to find the pressure contacts and clean them. But more than likely if a touchpad is bad it may need a replacement to correct the issue. I'm not as familiar with touch pads but typically they have little pressure-sensitive microswitches behind the rubber face plate that you see.
2015 ChevyHD D-Max
light
