Old 11-01-2018, 09:31 PM   #1
One awning support doesn't close all the way
I have an electric awning and when I close it, one supports closes snuggly again the camper, but the other doesn't. it's about 3/4 of an inch away from the camper. Is there a way to adjust this?
Thanks in advance for suggestions!
2011 Palomino Sabre 31 RETS
2014 F-150 W heavy duty tow pkg
Demco 13K Autoslide Hitch
5th Wheel Newbie
Dr ROK is offline   Reply With Quote
Old 11-02-2018, 08:17 AM   #2
Commercial Member
ES_FR's Avatar
Dr ROK,
We would be happy to assist you with this question regarding your Sabre's awning. Please contact Mikala Yoder in our Customer service department through the following personalized and direct link: Forest River RV Direct Service Contact - Forest River, Inc..
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will endeavor to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 11-02-2018, 10:09 AM   #3
brookstone345sa's Avatar
Try opening awning and check to see if the roller is lined up properly with the attached part on camper. Sometimes fabric has to be adjusted or slid in the track on outer edge. Its a common problem.
After adjusting mine to center, I put a rivet through fabric at tube part to keep it from sliding
brookstone345sa is offline   Reply With Quote
Old 11-08-2018, 05:33 PM   #4
I never thought of doing that, good idea.
nayther is offline   Reply With Quote
Old 11-14-2018, 07:13 PM   #5
On mine I have been bringing it in to about 18 inches at the top. I then push the rear arm up against the rig to get it aligned and release it (gently). Then finish bringing it it. May have to repeat but it snugs up nicely with this procedure.
AbdRahim is offline   Reply With Quote
awning
