Old 05-16-2016, 09:47 AM   #1
BandJCarm's Avatar
One hatch I can't lock
OK, on to the more minor of the things I found after I got her home......
The latch on the door where the inverter is....I can NOT lock it. It needs to be pushed in hard and I'm a big ole boy, and I can't push it in hard enough to turn the key. I am afraid if I force the key any more than I am, it will break the key off in the lock.
I'm not home, not near the camper, but thought I'd ask.....and in fact, all of the locks except the basement locks (a separate key and lock type) were/are hard to lock.
Ideas? WD-40 maybe? Replacement with something worth a dime???
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-16-2016, 11:08 AM   #2
If they're the standard cam locks you may need to slightly bend the tabs so they don't strike the lip so hard when closing the hatch door.
Gotta go campin!
Old 05-16-2016, 11:17 AM   #3
BandJCarm's Avatar
OK. will try that, thanks. I thought of some way to modify but that seems easiest to try first.
FROG AR-0019-242
Old 05-16-2016, 11:27 AM   #4
Make sure you take the tab off the lock before trying to bend.
Old 05-17-2016, 01:53 PM   #5
CaptnJohn's Avatar
Don't use WD 40 in locks. There is a graphite lube for locks by several companies.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
