03-27-2019, 08:26 AM
Ouch! I crushed my awning
Last fall when pulling out of a tight campsite I crushed the awning roller against a tree. The camper (2017 Roo23ws) was not damaged but about three feet of the roller was crushed. Anyone ever take their roller off the trailer, remove the awning, and repair such. I am wondering if the ends can be removed and the roller unrolled flat? That would really make it easy to repair. I am aware of the danger from the spring inside the unit. If all else fails, anyone know what a new roller (about 20 foot) would cost?
03-27-2019, 09:29 AM
I bought a whole new awning assembly when storm took out one on my old trailer. It was a manual awning. Got it from Ppl motor homes. You can go on their site and price. Good luck.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
03-27-2019, 09:34 AM
Be careful if you try this as some awnings have a spring in one end of the roller.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-27-2019, 09:42 AM
Recently new!
You might look and see if there is a local RV salvage place near you. Is the fabric OK? They might be able to sell you the roller tube and fabric as well. Might even be able to get them to install.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
03-27-2019, 09:43 AM
It might help to find out which awning you have there. Multiple products by multiple suppliers.
I just replaced my awning supports but had disconnected the awning tube on both sides.
I have a Dometic 9100 series power awning.
03-27-2019, 10:14 AM
Always Learning
There used to be a company called Mega X57 or something like that. They had inserts for this sort of thing. I can't get their website to come up now, though.
03-27-2019, 10:45 AM
If it's a Dometic 9100 Series I would contact Dometic at 800-544-4881. They will need the data off of your awning tag in order to point you in the right direction. I have seen my dealer replace awnings. It's a three man job.
2016 Salem 27RKSS
03-27-2019, 11:10 AM
Absolutely the awning roller tube can be replaced. I've replaced several for folks. It doesn't have to be a three man job.
As mentioned be sure you understand the basics of how the roller tube/spring mechanism works.
You can purchase just the tube (cut to length) and transfer all the hardware (end caps/spring/motor/awning fabric/etc.) to the new tube.
I have also had luck visiting a few R/V dealers and finding used tubes that are OK but the arms or other parts of the awning got damaged and they installed a complete new awning assembly for the owner under an insurance claim.
One such dealer had about 50 tubes (of various lengths) and maybe a hundred arms and various parts in his back parts bay. Had what I needed in 15 minutes for $25.
03-27-2019, 12:37 PM
Retired Member
Just watched a good video on Utube about replacing the awning that went into basics of unloading the spring tension along with install.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
03-27-2019, 01:20 PM
I just had to replace a Dometic 9200. The trailer was only two weeks old. Brushed by a small tree in our front yard. It ran $1,150 for the awning, arms and installation. Good luck!
Funny how those trees jump out and bite isn't it? Mine got damaged the same way at the dump site, going around a TT. Insurance covered it except for deductable. I suggest checking in to that.
03-27-2019, 01:35 PM
Here are 50 videos on awning replacement.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
03-27-2019, 01:38 PM
RVGEEKS and Mortins on the Move have posted YouTube video for replacing fabric. It requires the removal of the tube from the supports. You might want to check out their videos.
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
03-27-2019, 01:48 PM
replace awning
I replaced a 17' awning with a 21' on my old camper so I only needed the tube +- 300 and new fabric +-400 . Watch u tube its all there .Go slow.
2007 Yukon XL Denali 6.2 L awd
2004 Silverado 2500HD 8.1L
4/4 4.10 Allison 1200
New 2021 Brookstone 398 mbl 5er
57 years towing
03-27-2019, 02:08 PM
Unfortunately I have a $1,000 deductible.
03-27-2019, 04:01 PM
Damaged awning
My awning arms got bent, but my awning is fine. If you’re near Houston, I can sell it.
Anyone know a RV salvage near Houston ?
I also got quotes to fix for $1200.
I took the awning off ( MBS) , plugged the screw holes, and bot a 10x20 tent from Harbor Freight for about $100.
Awnings may be the most damaged item on RV, not worth the money to put one on, IMO.
03-27-2019, 04:04 PM
On a pre delivery inspection the dealer was explaining about the awning and the $1000 sail or sale. I hope you can get just what you need.
03-27-2019, 04:36 PM
Delaware Dave Follow-Up
Hey Guys, thanks for all the good and quick responses. I should have said this was a Dometic manual awning. Also, the awning itself is fine. I just crushed the roller tube. Checking with the local dealers for used rollers is a great idea.
03-28-2019, 10:07 AM
Be sure to call you insurance to check. The awning may be covered without a deductible.
03-28-2019, 10:38 AM
Youtube is your friend.
