Old 08-14-2016, 03:49 PM   #1
Outdoor kitchen door coming open while towing
Yikes! Our outdoor kitchen door pooped open several times while towing home today. Yes, it was locked, and yes, I checked it very well when latching it. But apparently the vibrations while towing caused it to shake open. Anyone have any suggestions???
NewJammer is offline   Reply With Quote
Old 08-14-2016, 03:54 PM   #2
Half-Timer
What type/model do you have? What kind of latches are on the door? I have a Sierra 378 FB and had concerns with the locking mechanisms. Dealer welded an extension on the lock plate to secure a better lock.
I'm considering installing slam latches in the near future.
Enjoying God's creation each day.
2015 Ram 3500 Laramie Limited with 6.7L Cummins Diesel
Forest River Sierrra 378FB
ptylerp is offline   Reply With Quote
Old 08-14-2016, 04:00 PM   #3
2016 Windjammer 3006WK. Latches are the same as on all the storage doors on the trailer.
Old 08-14-2016, 04:05 PM   #4
Half-Timer
As I said the dealer welded an extension on the lock mechanism (90 degree turn latch) so that it would firmly engage the metal plate behind the seal. My door has not come open but I was concerned until they made the modification.
In the future I will either find longer latch plate or install two slam latches on the door.
Old 08-14-2016, 04:39 PM   #5
If your locks have tabs like the 2 shown here, they come in different lengths. You may need to find longer ones. (And buying them by themselves is probably a PITA, too. You may need to buy the whole lock.)
2011 Traverse LT, 3.6L, FWD
Old 08-16-2016, 09:28 AM   #6
Wolverine 1945's Avatar
I would check with an RV dealer for longer tab,,, or maybe even a place that sells Truck Bed Shells ???
Wolverine 1945 is offline   Reply With Quote
Old 08-16-2016, 09:57 AM   #7
gectisme's Avatar
I believe they are called Slam Latches and we have 2 of them on the Outside Kitchen. On our first trip out, the door opened during the tow. I am not sure if I didn't close it all the way but I do know it wasn't locked. After that, I have a routine where I close it, pull a little to make sure it is closed and then lock it and pull hard to make sure it closed. It has not opened up since, ~4000 miles on the road and some of those roads were very bumpy... Having written that, when I look at where the latch goes in, it seems to be mounted just so it catches, they could have done a better job mounting the catches for the latch. I wonder if yours are mounted even worse... Since I have have not had any more issues I am leaving it alone for now but if it seems to get looser I will have to figure something out or wait for you to tell us what you came up with.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper).
MISSION COMPLETED!
gectisme is online now   Reply With Quote
Old 10-09-2016, 05:12 PM   #8
Still opening...
Still struggling with this. Installed flip door locks today - made it home (76 miles) with it flying completely open only once. Spent the entire drive staring at the door in the side mirror. Dreading the trip Friday when we will drive 3 hours...
ID:	122499   Click image for larger version
door, towing
