Old 11-13-2011, 03:15 PM   #1
Pass Thru Storage Doors Leaking?
Hello Not sure if this has been covered, Our 25DS Micro Lite was leaking in the pass thru storage area at the front of the trailer. We determined the water was leaking from the two access doors on either side of the trailer. The doors have 2 holes for drainage? on each side edge and one in the bottom edge. We believe that when there was a driving rain the rain entered thru the side holes and did not drain out the bottom hole fast enough. This caused the door to leak. we used allum. rivets to fill the holes on the side of the doors and drill a couple more in the bottom edge. This seems to have solved the problem. Hope this helps anyone else who finds water in the front pass thru storage area.
tbrew100 is offline   Reply With Quote
door
