11-11-2012, 04:23 PM
Plexiglass Storm Door
DW will not leave to the outer door open when I am cooking outside for any reason at all. She is a conservative and hates to waste the cold air inside. Anyway I have seen on other campers a Storm door with plexiglass instead of a screen. I have googled these many times but can't find anything. Anyone have one of these? Any idea where I can get one?
thanks.
Is it time to go camping yet?
2012 Wildwood X-Lite 281QB
2011 Ford F150 XLT 5.0L 3.73
11-11-2012, 04:52 PM
Just Love to Camp
We have done it. On two campers. You can take your screen door to a local glass shop and they will cut the plexi glass for you and install it. Or atleast the ones around here do!
11-11-2012, 06:06 PM
jdadoug
Plexi glass
I just use my table saw and cut it myself
Done several times on differnt projects. One of the key issues is to use painters tape or masking tape along your line that you want to cut, and to have a nice sharp blade. jdadoug
"Aint never nuthing easy"
11-11-2012, 07:00 PM
Camper Less Camping
I buy and cut myself then use double side Velcro tape to attach to screen areas, works great and we can easily remove to gain airflow in camper when not running AC.
2013 Sabre 32RCTS-6 (sold)
02-10-2013, 06:03 PM
I used a clear vinyl table cloth and cut it, to the same configuration as the door. I then used Velcro to secure it to the outside frame of the door. The nice advantage of the vinyl is , I can fold it up and store it in a drawer or closet. I would have posted a pic, but the rv is in, indoor storage for the winter.
( I hate keeping the door closed in the summer and fall )
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
08-23-2013, 07:00 PM
itch'n to road trip
I used my Dremel with a cutting blade for the plexiglass on our Graywolf.
Now have NEW Work & Play 25ULA and need to do the screen door there. This time I think I may need to use some flat clipe and small screws to hold in place. It has a differnt type of screen door set up than our Graywolf.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
08-24-2013, 04:27 AM
I cut all our plexiglass for our door. A top section...a middle section and a bottom section. So I can remove whatever one I want for air circulation. The bottom section has different spots with velcro so I just move the bottom section if wanted to allow a little air or a lot.
08-26-2013, 06:47 AM
Have done this mod on our last three units. Most difficult part is cutting the arc's to fit the top of the door. On the last two I made the top section in two parts - upper ends just below the end of the arc and the bottom goes to the door center. Makes it much easier to remove and re-install the top portion - should we take it out. I used a plywood blade mounted backward in my table saw to make the straight cuts.
08-26-2013, 06:53 AM
Clear Vinyl - what a great idea!
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
08-26-2013, 07:07 AM
I found the on-line store for clear vinyl. Clear Vinyl Fabric
08-26-2013, 07:11 AM
Here are the pics....
08-26-2013, 07:13 AM
You can buy clear vinyl in different weights from most Wally Worlds. My 2013 Cedar Creek came with plexiglass (vinyl?) inserts.
08-26-2013, 07:18 AM
one more pic....
08-26-2013, 07:25 AM
Lowe's will cut plexiglas to your specs for free, and they have several thicknesses to choose from. We velcroed it to the bottom half of our door only, to keep the dog out of the screen. Easy to remove when you want more airflow.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
09-02-2013, 07:11 AM
I have one installed.. Mounted it over screen door Brough the door to a window shop & had them cut the plexi glass to fit the door.Used a dark color helps keep sun out. Then a trip to home depot for the mounting clips I found the clips in the hardware dept. Think they are called screen door clips. bought them white & they look real nice against the dark gray of the plexi door. OH yea..had mine cut into 2 pieces & able to remove 1/2 for the nice cool days.
George & Judy... Our Quincy is gone but Never forgotten.
we now Have a Golden Doodle pup
2010 Brookstone. 2400 Watts of solar 1500w inverter,4 T105's
