Old 05-02-2015, 07:05 AM   #11
SYE
SYE's Avatar
Agreed Bubbles. Mine is working great
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 05-02-2015, 07:09 AM   #12
SYE
SYE's Avatar
Bob, you can set the limits, then push the bottom momentarily and it were stop where you have the limits set to. I set mine up this way originally, but I then moved the jumper and set it like the rm66. I also programmed my old RM66 remote to be used with this as well, so now I have 3
Scott & Vicki
Old 05-02-2015, 08:17 AM   #13
TURBS's Avatar
Glad this unit is working as well as the last!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 05-02-2015, 10:33 AM   #14
Left Coast
I'm sitting here with the unit and my question is about the jumper. Mine came with no paper work, and the fob is confusing at this point as I can't test anything till the other awning motor gets here. I've put 12v direct to the one 's that there and nothing happens, so today I'll be pulling the thing out and see how it's all held together.My awnings rolled up so this ought to be fun.
Old 05-02-2015, 10:57 AM   #15
bubbles's Avatar
This might help. Notice the last paragraph.
Old 05-02-2015, 11:06 AM   #16
Left Coast
Thanks..... It's the jumper that I'm being confused by. How to and where to?
Old 05-02-2015, 11:14 AM   #17
bubbles's Avatar
Looking down inside the unit notice JP2 and it will have pins sticking up. One of the pins may have a small plug on it. That is the jumper plug. Pull the plug up and out then reinsert on the two JP2 pins to short them together.
Old 05-02-2015, 11:17 AM   #18
Left Coast
YOU THE MAN! Thanks
Old 05-02-2015, 11:21 AM   #19
bubbles's Avatar
After the shorting of J2 the 2 remote control arrow buttons will function the same as the RM66 did (press a button and awning rolls, release button and awning stops). The 3rd remote button is not used.
awning
