Old 09-27-2016, 08:39 AM   #1
Power Awning
New Shasta Flyte 185FQ. Mabee dumb ? But, my rocker switch is not marked in And out so when rolling up awning should the underside of awning be on outside or inside??
Decon Blue is offline   Reply With Quote
Old 09-27-2016, 08:44 AM   #2
Flybob's Avatar
Underside of the awning should be rolled up inside. Top of awning should be showing when rolled up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-27-2016, 08:45 AM   #3
Underside inside for me. This results in no where for rain to collect when the awning is rolled up.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2019: 34 nights camped
Teamfour is offline   Reply With Quote
Old 09-27-2016, 08:46 AM   #4
Inside.
Here is a picture of my topper awning I found quickly.
The main awning is the same principle.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 09-27-2016, 08:53 AM   #5
Inside.
You mean underside to the inside ? Your pic looks that way. Thanks for all replys !
Old 09-27-2016, 09:49 AM   #6
Yes.
Your question in your first post was... "so when rolling up awning should the underside of awning be on outside or inside??"
My answer is still the same... the underside of the awning should be... 'inside.'
Old 09-27-2016, 09:52 AM   #7
Georgia Rally Coordinator
aceinspp's Avatar
Looks like you will be marking your switch so you know. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 38
aceinspp is online now   Reply With Quote
Old 09-27-2016, 09:58 AM   #8
AquaMan's Avatar
I didn't even think it was possible to roll the awning up inside out, but evidently it is.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 09-27-2016, 10:01 AM   #9
AquaMan's Avatar
The more I think about it, it shouldn't be possible. Wouldn't the spring would continue to wind up, unless of course the spring is broken?
Old 09-27-2016, 10:15 AM   #10
Some of these newer power awnings do not have springs. They will simply continue to roll up in the opposite direction once extended.
For those that do, (have springs) you are right, it would continue to wind the spring but they don't have near the static tension (number of winds closed) the old manual awnings have so I'm thinking the spring might not break. Probably not good for the motor and gears though when it gets that many turns on it.
awning, power
