04-07-2015, 08:46 PM
Power awning rolled up under-side out
First trip, I extended the awning all the way. At the end of the day I retracted the awning and it rolled up with the under-side on the outside. Worried all night. Next day rolled it out just shy of fully and retracted it and it rolled correctly.
Is there a problem or do I just need to not fully extend it?
04-07-2015, 08:51 PM
I would guess your switch is faulty as it didn't reverse.
04-07-2015, 09:55 PM
Any chance that you mistakenly pushed the extend when you wanted retract? It will roll up the awning inside out.
Dave
04-08-2015, 02:12 AM
Originally Posted by Dave_Monica
Any chance that you mistakenly pushed the extend when you wanted retract? It will roll up the awning inside out. Dave
After thinking about it, would the torsion spring not have to disconnect from an internal stop or fail for it to roll backwards?
04-08-2015, 06:39 AM
Sounds like a torsion spring fail otherwise it's not possible.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-08-2015, 06:52 AM
Mine has done it a couple times over the span of a year. It typically happens if I over extend the roll out. I just stop and roll it out again and when retracting it is correct. There is no issue with mine and am on the 4th year of ownership and to many cycles of the awning to count.
04-08-2015, 07:08 AM
Dave
What Dave said! X2
Peace!
Dan & Rita D
04-08-2015, 07:12 AM
Dave
Originally Posted by KyDan
What Dave said! X2
I don't think that's possible with the torsion spring.
Unless the torsion is broken.
TURBS
04-08-2015, 07:16 AM
I hear you but think about it. The only way to roll it inside out is to
continue turning the drum in the direction it turns when opening....
TURBS
Or a Real Strong motor! Youroo!!
04-08-2015, 07:17 AM
Originally Posted by youroo
Or a Real Strong motor! [emoji106] Youroo!!
Big block 502 powered!
TURBS
04-08-2015, 07:46 AM
I may not be as experienced as some of the people on this board, and generally try not to disagree with their assessments - but this time I'm going to
With a manual awning I would agree there is no way for it to roll up backwards, but with an electric awning - absolutely. There is no 'hard stop' on an electric awning, it just unrolls until extended and if you don't take your finger off the button the motor keeps spinning which will result in it rolling back up inside out using the tension created on the awning and the catalyst to travel back to the closed position.
I don't believe there is anything wrong with your awning, just probably pressed the wrong button when trying to retract.
Craig & Lynn D'Angelo
Delaware
04-08-2015, 07:50 AM
I'll respectively disagree.
The power awning has a torsion spring just like the manual awning.
TURBS
04-08-2015, 07:53 AM
Sorry folks, the only way it will roll up backwards is if the torsion spring is dis-engaged or broken in the opposite end of the motor.
04-08-2015, 07:54 AM
Thought they could only go out a till they were open. When I open mine it goes out and stops on it's own, thought there was a limit switch somewhere in the thing. Also thought the spring couldn't let this happen would have to think the spring is not connected anymore. Make sure and secure it somehow, so it can't open while going down the road, before you transport it for repairs since what normally holds it in probably isn't working either.
Think about things before you do them make life easier not harder.
To bad we didn't take pictures when yours was apart in goshen! [emoji106]
TURBS
04-08-2015, 08:04 AM
Unless you wrap something around the roller, there is no way to keep it from unrolling while going down the road other than the motor itself. I made a tab that I lock down to restrain the roller itself.
04-08-2015, 08:25 AM
I think the first question we should ask here is: What model awning do they have? If it's a Dometic then yes, there is a torsion spring, but it could be one of the LCI / Lippert. If so, then there is no torsion spring, only a motor and it could be rolled inside out.
TT- 2014 Grey Wolf 21RR
TV- 2009 Nissan Titan (with Big Tow Package)
04-08-2015, 08:31 AM
True, you are correct.
04-08-2015, 08:48 AM
If it's a LCI Solera power awning, there isn't a internal torsion spring like in a Dometic or Carefree.
Dave
