Old 04-07-2015, 08:46 PM   #1
Wobbles's Avatar
Power awning rolled up under-side out
First trip, I extended the awning all the way. At the end of the day I retracted the awning and it rolled up with the under-side on the outside. Worried all night. Next day rolled it out just shy of fully and retracted it and it rolled correctly.
Is there a problem or do I just need to not fully extend it?
Wobbles is online now   Reply With Quote
Old 04-07-2015, 08:51 PM   #2
I would guess your switch is faulty as it didn't reverse.
Old 04-07-2015, 09:55 PM   #3
Dave_Monica's Avatar
Any chance that you mistakenly pushed the extend when you wanted retract? It will roll up the awning inside out.
Dave
Old 04-08-2015, 02:12 AM   #4
Originally Posted by Dave_Monica View Post
Any chance that you mistakenly pushed the extend when you wanted retract? It will roll up the awning inside out. Dave
After thinking about it, would the torsion spring not have to disconnect from an internal stop or fail for it to roll backwards?
Old 04-08-2015, 06:39 AM   #5
TURBS's Avatar
Sounds like a torsion spring fail otherwise it's not possible.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-08-2015, 06:52 AM   #6
bubbles's Avatar
Mine has done it a couple times over the span of a year. It typically happens if I over extend the roll out. I just stop and roll it out again and when retracting it is correct. There is no issue with mine and am on the 4th year of ownership and to many cycles of the awning to count.
Old 04-08-2015, 07:08 AM   #7
KyDan's Avatar
Dave
What Dave said! X2
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-08-2015, 07:12 AM   #8
TURBS's Avatar
Dave
Originally Posted by KyDan View Post
What Dave said! X2
I don't think that's possible with the torsion spring.
Unless the torsion is broken.
TURBS
Old 04-08-2015, 07:16 AM   #9
KyDan's Avatar
I hear you but think about it. The only way to roll it inside out is to
continue turning the drum in the direction it turns when opening....
Old 04-08-2015, 07:16 AM   #10
TURBS
Or a Real Strong motor! Youroo!!
youroo is online now   Reply With Quote
awning, led, power
