Old 11-11-2012, 05:59 PM   #11
Herk7769's Avatar
10-15 seconds is what mine takes. Twice that means something is wrong.
HAM CALLSIGN - KC3FFW
Old 11-11-2012, 06:07 PM   #12
Okay thanks
Grey9712 is offline   Reply With Quote
Old 11-11-2012, 07:47 PM   #13
One more thing.two times the only way to get the awning out was to hit retract not extend.This has only happened twice I have no idea what could cause this.
Old 11-11-2012, 07:51 PM   #14
IMO, all the more reason to believe the awning material is not centered on the roller and it is putting all the arms in a bind.
Old 11-11-2012, 07:53 PM   #15
Ok thank you much.
Old 11-12-2012, 11:00 AM   #16
Take it back and get it fixed, 37 seconds is to long.
whj77372 is offline   Reply With Quote
Old 11-12-2012, 12:16 PM   #17
Agree, but only after seeing if the material is centered on the roller. If it is centered I would take it back. If not, I would center it and see if that cured the problem and if it didn't, then back to the dealer.
Old 11-12-2012, 01:48 PM   #18
Thank you.If it is centered on the roller and nothing improves is it a matter of preference? Like no hazard with it because the dealer is two hours away and i didn't plan on taking it to the dealer until the end of next camping season for maintenence.
Old 11-12-2012, 01:58 PM   #19
If it were me and centering the material didn't cure the problem, I would attempt to increase the number of turns on the torsion spring. Consult the manual for doing this as it can be a little dangerous if not done correctly. I would make the torsion spring adjustment with the awning only about a foot from the stow position to minimize the amount of torsion on the spring and make it easier to put another turn or 2 on the spring. With you stating the awning gets stuck in the stow position sometimes, I highly suspect the material is off center.
Old 11-12-2012, 02:02 PM   #20
Ok it doesn't get stuck the switches just did opposite of what they were supposed to.
awning
