Old 06-06-2013, 08:51 PM   #1
member
power awning sticks
Hi all, When I extend my power awning one side seem's to stick and then extend with a thud.It's done this sense day one but is seem's to be getting worst. dealer told me at my PDI this was normal. but sense it is sticking longer I was wondering if theirs a problem and if anyone else has this issue? thanks for any info.
2016 Rockwood 8310SS Signature Ultralight
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 06-06-2013, 08:54 PM   #2
Denver, CO
garbonz's Avatar
Need to look at the other posts on the fabric alignment and riveting. It splains it all.
2017 Fuse 23T
Old 06-07-2013, 06:26 AM   #3
Herk7769's Avatar
yes, your dealer was incorrect. This is not normal and the awning arms are most likely hanging up on the pivot pins due to slippage of the material as previously suggested.
Stand on a ladder and look at the roller where the fabric ends and look for a "dirt line" where the awning used to end. It might be visible on the other end.
Lift the awning roller slightly to release pressure on the slots and "flap" the material while gently tugging on it to pull the material back into position.
Run the awning in and out several times to make sure it is back to normal.
If it is, a permanent fix is to pop rivet the material so it will no longer move in a wind.
HAM CALLSIGN - KC3FFW
Old 06-07-2013, 07:25 AM   #4
CheezPack's Avatar
Thanks for that info, ours does the same thing! Question? Won't the material tear at the rivet point in the wind? Should there be some type of washer that goes in too?
2013 Sabre 34 RLQS
2010 Ford F250 diesel
FRF & FROG member
Rallies 12 & 13, Cherry Blossom 13, Branson 13... More to come!
CheezPack is offline   Reply With Quote
Old 06-07-2013, 08:09 AM   #5
Herk7769's Avatar
If you use a larger diameter (but short) pop rivet (Called Large Flange Head), the rivet has a large "head" and will easily retain the fabric.
POP - SSD66SSBSLF - All Stainless POP Rivet
or aluminum
http://www.bylerrivet.com/products/i...s.aspx?pid=210
Old 06-07-2013, 08:19 AM   #6
Yes you can place a (soft-washer) between the rivet head and the fabric to protect. Youroo!!
