Old 05-08-2012, 11:58 AM   #1
Drakconian's Avatar
Power Awning Tie Down?
Is there a way you can secure the power awning while travelling? I have read stories where the power awning has unrolled while in transit and I would feel a lot better knowing that it is secured manually as well.
2012 Primetime Lacrosse 318BHS
2003 GMC 2500 HD Diesel
Reese 1200lbs Dual Cam SD Hitch
Drakconian is offline   Reply With Quote
Old 05-08-2012, 12:52 PM   #2
lindy's Avatar
I use the same velcro tie straps with my power awning as I used with my manual awning. They're less the $10.00 at CW.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 05-08-2012, 01:03 PM   #3
Drakconian's Avatar
Where do you put them, any pictures if you have them would help.
Thanks.
Old 05-09-2012, 07:26 AM   #4
lindy's Avatar
The vertical awning frame member that's rivited to the side of the trl has a very small gap between it and the trl side. I just slipped the velcro strap thru the gap and then around the arm assemblies and straped them tight to the frame member. Like you would with the manuel awning arms.
F.R.O.G. member
Old 05-09-2012, 08:29 AM   #5
Drakconian's Avatar
Thanks, will be doing that today.
Old 05-09-2012, 09:08 AM   #6
The velcro straps will keep the arms in the stow position, but if for some reason or other the motor releases the tension on the roller, the awning material will still unroll and become a sail. There are roller locks available that actually contain the roller to prevent this and likewise hold the arms in the process.
Amazon.com: RV Awning Clamp (Black): Sports & Outdoors
Old 05-09-2012, 09:23 AM   #7
The vert. awning frame member thats riveted to the side of a (Smooth) side trailer should be tight (No gap) between it and the wall. If there is a gap,space the rivets were not put in properly or delamination is occur ing. Now if the trailer is a corrugated siding there is a space for the strap to pass thru. Youroo!!
Old 06-11-2012, 02:31 PM   #8
Here is how I lock my power awning for transport. It is very simple and effective as it locks the roller and cannot be turned even by the motor.
Simply drilled the end of the roller @ the end of the slot on the motor end and tapped it for a 3/8-16 UNC bolt, made a tab and screwed it into the hole/slot. Made a hook with a turnbuckle and fasten the top hook in the roller tab and the lower hook is under the bottom of the wall support and tighten the turnbuckle. Complete set of pictures @ Forest River Forums - dunnnc's Album: Awning lock
Name:	Alum tab, 3-8 x 1-2 ss bolt, washer & nyloc nut.jpg
ID:	15131   Click image for larger version
Name:	Awning lock top close up.jpg
ID:	15132   Click image for larger version
Name:	Awning lock turnbuckle.jpg
ID:	15133   Click image for larger version
Name:	Bottom hook unlatched.jpg
awning
