Old 10-22-2018, 05:10 PM   #1
moshe1436's Avatar
Product to clean awning
After 6 months in storage there are unsightly stains on the underside of my awning caused by rain seeping in from the edges when rolled up.
Two questions:
#1 what is the best product and method to manually clean it?
#2 how to stop the water from doing this when rolled up?
moshe1436 is offline   Reply With Quote
Old 10-22-2018, 05:19 PM   #2
Flybob's Avatar
I used this. Worked well, but you need to rinse it off awning and sides after cleaning.
https://www.amazon.com/Concrobium-Mo...ATS4B4VF95WPHA
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-22-2018, 05:27 PM   #3
https://www.wetandforget.com
Put in a pump up sprayer spray it on roll it up and spray it off in the spring.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 10-22-2018, 05:40 PM   #4
Decon Blue's Avatar
Clean with Simple Green, let dry, then use Wet and Forget as directed on label. Easy Peasy.
Retired and loving it. Still looking for that perfect high.
Decon Blue is offline   Reply With Quote
Old 10-22-2018, 08:21 PM   #5
moshe1436's Avatar
Wow! Thatís great! Thanks!
Old 10-22-2018, 08:40 PM   #6
kenandterry's Avatar
Just a thought.......
Is there any way to bag the ends of the awning when itís rolled up for long periods of time......obviously like in storage as you describe? You seem to indicate youíre convinced the water gets in from the ends.
Just sayiní
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 10-23-2018, 09:46 AM   #7
moshe1436's Avatar
Just sayiní
Yep! Thatís what I will try. Got to do something to stop this from happening every time itís rolled up! Thanks!
Old 10-23-2018, 10:03 AM   #8
Decon Blue's Avatar
Iíve seen where some folks take a 2litre Pop bottle and cut the top off and slit the side to be able to slide on each end while rolled up. Donít think this will work for moving down the road but might help for long term storage.
Old 10-23-2018, 10:05 AM   #9
DAISY BOYKIN's Avatar
Mold removed from awning
I used a product from Lowe's the you use to clean the mold from Vinyl siding.
Comes with a end of the hose sprayer. It has a clinging agent in the solution
so it will cling to the surface of the awning.
If you have a B.J's Club near you, B.J.s has two gallons for about 1/2 the price as what Lowes charges. Located near the light bulbs & motor oils in store.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 10-23-2018, 10:13 AM   #10
D W
D W's Avatar
It is the nature of the beast. Just one of those things you have to deal with. I use Mr. Clean or Spic 'n Span with a telescopic soft bristle brush to clean it as needed. "Bagging" the ends seems like it would be futile. How would you fasten the bags around the awning roller tube? One trip down the road and it would look like a garbage truck.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
awning
