Old 08-11-2016, 03:24 PM   #1
Pull Down Shades
Anyone know how to adjust the tension on the pull down shades on Wildwood 27RLSS. Upon delivery, the shades were too loose and fell down. Now, after taking it in for service, they are too tight and it's hard to put the shades up without 'wrinkling' the shades.
mhayes is offline   Reply With Quote
Old 08-11-2016, 03:42 PM   #2
Most day/night type shades are tension adjustable via the string/holder, fastened below the shade on each side if that's the kind of shade you have.
Sometimes you can loosen the screw and rotate the string holder to free up or tighten the resistance, dependent upon which way you rotate the string holder.
Sometimes you have to tie a new knot in a different place on the string.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 08-11-2016, 03:48 PM   #3
Thanks. I'll give it a try!
Old 08-11-2016, 03:56 PM   #4
rattleNsmoke's Avatar
If the shades are tight, the strings may be dry. You may wanna first try to slick them up with a candle wax or soap.
rattleNsmoke is offline   Reply With Quote
Old 08-12-2016, 01:23 PM   #5
According style shades are a pain best answer is to replace with MCD shades. Much better but not cheap. Go to their website and check it out.
ingalmi is offline   Reply With Quote
