Old 07-18-2015, 09:01 AM   #1
Crockett's Avatar
quick step fix
IF...IF you got a step thats ripping where the angle at the front mount is bolted through the floor. and IF its got the 4" plate welded vertically to the frame at the rear. THEN this repair might be for you... I put a 2.5 inch box piece at the bottom with a tek screw. You'll have to get a good prybar. Now the top is in tension and the bottom in compression. Just forget about the rip up front shes hella stout. Hope this saves someone!
Crockett is offline   Reply With Quote
