Old 06-13-2018, 11:23 AM   #1
Rafter arm keeps popping out of the lower track
The rear rafter arm of my awning managed to come completely out of the lower arm groove. Before my last trip I took the set screws out and forced it back into the rail. It took a little force but moved freely after a few squirts of WD-40. Got to camp and extended it and one side was popped out of the groove again. What gives? Is it twisted or something?
NVSmithers is offline   Reply With Quote
Old 06-13-2018, 11:50 AM   #2
AquaMan's Avatar
Not sure I understand. Any pics?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 06-13-2018, 11:56 AM   #3
Assistant TP Supervisor
B and B's Avatar
This a manual awning I presume . The only thing I found that worked was to use some silicone spray and lube the channels. Also taking it slow moving the arm helps keep it in the track.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-13-2018, 12:01 PM   #4
Its what this fellow here has a hold of. The bottom part of the slider there pops out of the groove in the bottom arm.
Old 06-13-2018, 12:03 PM   #5
Yes manual, I guess ill give it another shot and see what happens. Thanks
Old 06-13-2018, 12:10 PM   #6
Just a though, are you loosing the two screw knobs before you open the awning? (The one just above the man's hand in the picture.)
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 06-13-2018, 12:47 PM   #7
Yes, I sure am.
Old 06-13-2018, 01:36 PM   #8
Rafter Arm Popping out.
I had the same problem, one of the "wings" on the part was bent. I replaced it
Amazon has the part for about 15 bucks look under RV Awning parts for slider assembly w/143002.055 rivet for A&E.
Petedeboer is offline   Reply With Quote
